GM Distributor
Discussion in 'The Hokey Ass Message Board' started by D.R.Smith, Mar 28, 2013.
  1. D.R.Smith
    D.R.Smith
    Does anyone know why GM put the distributor in the rear of their V8 motors.Back when point's where your only option,I can remember thinking what a dumb idea lit was. Getting the screws started in the point's and condenser,was quite a challenge.
  2. brokenspoke
    brokenspoke
    Cause the oil pump is back there...I'm glad it worked out they way its done....rear sump is much easier for engine swaps
  3. that's where God intended them to be
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    From '57 on, all of the General Motors V8s had the window in the distributor cap that made adjusting the points a snap, no matter where the distributor was.
  5. GassersGarage
    GassersGarage
    It looks better too in Hot Rods without hoods.
  6. kracker36
    kracker36
    Having the distributor in the front is a terrible design---------especially in a performance application. No well designed performance engine should have the distributor in the front. Here are a few examples of poorly designed engines that would never win any type of compe***ive event:
  7. badshifter
    badshifter
    To increase wheelbarrow sales.
  8. treb11
    treb11
    because back then gas was 25 cents a gallon, cars were big enough for a real engine compartment where it didn't make a tinkersdamn where the distributor was.
  9. Dan
    Dan
    I'd love to find one of those old conversions that allowed you to put the sbc dist. in the front of the engine, probably a pita but I think theyre kinda cool...
  10. badshifter
    badshifter
  11. FityFive
    FityFive
    That is funny!! Great looking engine, thanks for sharing.
  12. Saxman
    Saxman
    That's funny, right there!!! :D:D
  13. Mr48chev
    I can guess that D.R. Smith doesn't have a Y block in his F-100 panel. Who would have thunk that Ford of all manufactures would put a distributor right there in that spot.
  14. Bobert
    Bobert
    And if it was good enough for GM it was good enough for John Q. Public
  15. hotroddon
    hotroddon
    They did it because of oil pan and pump design for packaging of the engine into various vehicles. But from a performance stand point it is a terrible design as it makes ignition timing very unstable due to camshaft "whipping", it also puts a larger load on the rear cam bearings. They finally figured it out on their NASCAR motors with R07 motor of 2009.
    Of course that motor so closely resembles the Ford NASCAR FR9 that one team put a Ford head on a R07 and made it run!
  16. Well your first problem is that it's GM....mopar's where it's at *big grin*
    1shot
  17. ugotpk
    ugotpk
    The best reason was when you launch a car the fluid is forced to the rear of the pan. Works just as well to just have the pic up for oil back there. Then baffle it. You guys going back an forth about my Chevy is better then your Ford all know it just comes down to who has the most bucks. PPHHHHTTTTT
  18. What did the mechanics think about the 57/8 Fords with the hoods that opened backwards. That would have made it more difficult to change a thermostat, water pump problems on those I'm sure.
  19. 38Chevy454
    38Chevy454
    Yep, GM sure let two slip by with 67(?)-up Cadillac and Buick V8s with distributors up front.
  20. D.R.Smith
    D.R.Smith
    So it looks like there is no real reason.Just another case of the guy designing it didn't have to wok on it.Just like the backward hoods.
  21. CB_Chief
    CB_Chief
    from Oklahoma
    It may seem odd placement to front distributor supporters but I never had a Chevy engine die due to moisture in the distributor while driving on a rainy night.
  22. cavman
    cavman
    It's just purtier back there :)
  23. belair
    belair
    So old Fords could go fast.
  24. Reminds of when I worked in a shop with a couple O.T. early 80's Fairlane loaners with 6cylinders. If you drove through a puddle with them they would quit. We ended up putting some factory Ford condoms on them and they were good after.
