Hot Rods GM engine identification
Discussion in 'The Hokey Ass Message Board' started by Rattle rod, Jun 13, 2016.
  1. Rattle rod
    Rattle rod
    Can anyone out there help me with an engine code? V0526EBM
    from what i can find online the V=Flint 05=May 26=26th...but EBM is a suffix i haven't found yet.
    it's possible this is an industrial 350 out of a Massey combine, but i'm not certain. Thanks
  2. Russco
    Russco
    from Central IL
    What casting numbers ? Head casting marking?
  3. Rattle rod
    Rattle rod
    heads have been changed...so no luck there.
    i'll get the casting number later today
  4. FrozenMerc
    FrozenMerc
    350 out of a Corvette.......
    Weren't they all???
    Sorry I am no help.
  5. squirrel
    Without some more info to at least narrow it down to a decade, it's hard to say. The three letter suffixes started in 1970, could be anything....they are still making them...
    Pictures? casting date code and casting number from the back of the block, above the bellhousing area? partial VIN from the same area as the number you already posted?
  6. treb11
    treb11
    You already know what it is and what it's from. What new information do you hope to gain? The cam is probably wrong from street use? is it a core or do you want to run it as -is?
  7. Rattle rod
    Rattle rod
    Casting number 3970010.
    I'm just interested to know what it is that I have. It's running and driving in our model A RPU. We were in our first car show over the weekend and people asked about the source for the engine. Some discussion came up about the suffix possibly being an industrial motor. Possibly a Massey combine. To me as a relatively new hot rodder, the back story on the motor is just interesting.....
    Any help is appreciated.
    Sent from my SM-G920W8 using H.A.M.B. mobile app
  8. 3970010 is a basic 350 style 4-inch bore casting, but to narrow it down better you still need the casting date, which is located on the bellhousing, opposite side from the casting number. 3970010 is a good block, some were 4-bolt, but most are 2 bolt.
  9. squirrel
    Does it have the partial VIN stamp next to the stamped code you posted? If not, then it could be an industrial engine....???
    The block casting number was used from 1969 to 1979, mostly on truck engines, and the truck suffixes in the 70s almost always started with the letter T. The E thing is weird, and could be an industrial engine.
    Either way, it's a good story, so don't let the facts get in the way of telling it...
    (and almost every 010 block I've seen is a 4 bolt)
  10. Rattle rod
    Rattle rod
    There is no vin on the block. Unfortunately I cannot access the date on the back of the block[​IMG]
  11. squirrel
    can't help then...at least you have an idea what it is, a 350 from the late 70s (judging by the character of the stamped numbers in your picture) that was not installed in a car or truck. I guess you can make up whatever story you want for it?
