Ta hell with additives. If you are concerned run the Valvoline "Off Road" oil. It has all the ZDDP the old oils had. On start up, Use the ***embly lube and "Off Road" oil. Valvoline's "Off Road" oil ***le is just a way around the EPA rules on packaging. Even this will go away at some point.
