GM Gaskets
Discussion in 'Parts For Sale' started by Ben Chirco, Aug 22, 2024.
  1. Ben Chirco
    Ben Chirco
    City: Hopkinton
    State: Massachusetts
    Price: 200.00
    GM Delco 1950s-1970s engine/transmission gaskets
    ALL NOS, PARTIAL LISTING, MORE TO COME
    mostly 1950s-1970s
    #74235 77402A #74235 Washer, 700-R4 Input Carrier to Race (Plastic) 1982-85-8.00 have one
    #19900 2002 6201-6210 BW T-35 Transmission Gasket & Seal Kit 1962-71 Rambler & More T35, one set 70.00
    #6256356 transmission overhaul ring kit 1981 MD3 transmission-1 set, 1960-1969 Chevrolet Corvair NOS Powerglide pan gasket - have 5, 5.00 ea
    #3727235 1957-61 Chevy Powerglide Pan Gasket 1961 1960 1959 1958 1957 Chevrolet set of 3- 30.00
    Powerglide Overhaul Gasket/Seal Kit W/Rubber & Rings 1962-66 Chevrolet open box-10.00
    3876199 1966 66 Chevrolet Chevy Truck 366 Engine Gasekt -15.00
    # 347096, 3849968, 6263005 POWERGLIDE TRANSMISSION FILTER, 1962-1973, Part No.515542, 10.00OEM RARE Pack of 3 GM Gasket 6255758 GR 5.508 76F3 20.00 for 3-
    #3760655, 1948-1963 Chevrolet 4 Speed Transmission Gasket Kit NOS 15.00
    #3799214, 1962-63 CHEVY PONTIAC GMC POWERGLIDE TRANSMISSION PLATE -5 qty-20.00 ea
    #3814713, NOS 53-61 CORVETTE 53-62 Chevy Pass Transmission Seal Unit (.120 Thick) -2 sets, 15.00
    #3849968 automatic transmission filter kit . NO. 701CX powerglide 1962-1973
    # 8623965, 1965–1981 General Motors NOS Transmission Overhaul Gasket Set GM, $45.00, transmission overhaul gasket set-1 set
    # 591451, 1955-1967 CHEVROLET VINTAGE NOS 4 SPEED TRANSMISSION CASE GASKETS- 3 of them-14.00
    #3814713 TRANSMISSION SEAL KIT. 1953-1961 POWERGLIDE-not sure, NOS 1942-1956 Cadillac Oldsmobile Pontiac Hydramatic Front Transmission Oil Seal-2, 25.00
    #3751802, turbo glide transmission seal kit 1957-1961-85.00-5 sets
    #1393984, Buick trans kit rebuild BUICK 1948-1952; ALL MODELS - WITH D SNAP RING SET-TRANS-70.00 #3783287, CLUTCH PLATES Forward NOS Powerglide CHEV -5 sets 120.00
    1958 59 60 61 62 CORVETTE C1 NOS GM POWERGLIDE TRANS. CONVERTER SEAL KIT 3776875-55.00-1 set
    6255758, Pack of 3 GM Gasket -20.00
    #3764407, 1958 – 1962 Chevrolet NOS Power Glide Transmission Gasket Set GM $65.00-1 set 2400548 transfer case cover 1960 -69 gasket- 5 of them
    Original GM NOS Muncie 4 Speed Transmission Gasket Set # 3917763-1. 4.00 Consists of crankcase front end cover gasket and seal assembly, water pump gasket, crankcase rear bearing oil seals, fuel pump gasket 95.00 1963 – 1967 GM #3834936, Engine Tune Up Gasket Set NOS, 6 cyl- one set
    #3732282, 1957-1961 Chevrolet Belair Impala Turboglide Rear Pump Seal Qty 1-5.00
    overhaul kit for a Powerglide transmission. includes: Gaskets, lip seals, O-rings, sealing rings, friction lined clutches, steel clutches, front pump seal for steel clutches, pump seal and extension housing seal. This part fits most 1953 1954 Chevrolet Cars1976 – 1981 GM Transmission Rear Bearing Extension Gasket NOS # 7316448, $5.00 one Gm Nos #3844206 powerglide auto trans clutch piston 64-70 corvette nova chevelle. 50.00 one of them. Clutch Piston fits 1964-1972 Chevrolet8630475 Automatic transmission plate 1976, m-29 automatic transmission- 1 of them price???NOS 5258443 GM Hydramatic Transmission Valve Body Gasket 10
    00 have 1
    1969 – 1975 Chevrolet Pickup Transmission Adapter To Transfer Case Gasket GM # 3950469$18.00- have 5
    #3935449, GM FRONT TIMING COVER GASKET. PACKAGE OF 8 GASKETS. 10.000 each
    NOS 1970-1975 Chevy Olds Sprint transmission Valve Body Spacer Plate Gasket #330190 / 6261678-9.00 one
    Differential Cover Gasket 1964-1981 gm 3844178-have 4.5.00 eachfront hub gasket fo22 ,25 ifs025,030,035 fo40 ifs040 shield gasket. 6.00 have 11
    GENUINE GM NOS 8628724 gr 4.163 - WASHER (Low & Reverse Clutch)-1-27.00FEL-PRO RDS 13391 - Differential Cover Gasket-1967-1981 gm-6.00-have 2lower valve body gasket for GM's Powerglide automatic transmission from 1962 to 1966.OEM # 3840330 & 3840331, NOS GM Corvette Powerglide Valve Body Gaskets 62-66 Chevelle and Corvette 3840331 25.00 eachGM 6259036 TRANSFER CASE GASKETS.22.00 have 2,
    1973-1974 GMC Blazer Jimmy OEM Type 2031948-1963 Chevrolet 4 Speed Transmission Gasket Kit NOS 3760655. partial kit 15.00
    FEL-PRO RDS 13391 - Differential Cover Gasket, 1964-1981-2 of them 7.00Transmission Rebuild Kit For Powerglide,Item # 3703919A 53-54, Weighs 1.8300lbs.GM 3752756 GASKET SET- 4 sets-60.00
    1963 – 1967 GM Engine Tune Up Gasket Set NOS # 3834936$95.0-6 cyl- one set This is a rebuild kit for 1953-54 Powerglide transmissions. Includes gaskets, lip seals, O-rings, seal rings, (short set) front pump seal and extension housing.This part fits most 1953 1954 Chevrolet Cars-4 sets 225.00Chevy 348 409 V8 Front Timing Cover+Water Pump Gasket Set+Seal BEST 1958-1965. 3775707, 3998212- one set 25.00
    1963 – 1967 Corvette Concealed Headlamp Opening Cover Pivot Felt Seal NOS # 3826148-5 of them 18.00 CHEVROLET 3 SPEED MANUAL TRANSMISSION WITH OVERDRIVE GASKET KIT 3910117 NOS-85.00 2 of them
    #8628975, 1976-1977 Chevrolet Chevette Transmission Spacer Plate Gasket (1) NOS-15.00
    #7420925, 1967-1970 Chevrolet PowerGlide Transmission Valve Body Gasket -2 of them 30.00
    # 3703919, Transmission Master Overhaul Kit For Powerglide, Item, Powerglide transmission. includes: Gaskets, lip seals, O-rings, sealing rings, front pump seal for steel clutches, pump seal and extension housing seal., This part fits most 1953 1954 Chevrolet Cars
    59-61 Chevrolet Turboglide Automatic Transmission Gasket Set BOWMAN 3760222-2 sets. 40.00
    1950 – 1952 Chevrolet Transmission Gasket Set NOS # 3701030, - 3 sets. $125.00, New Old Stock From G.M.
    National Oil Seals Seal, Front Transmission ; 6712NA, 5740339, 8626916, 5330-01-025-4212-1 12.00
    #3932255, 700R4 4L60E TH350 Extension Housing w/o Flange -1-2.00
    #5258041, automatic transmission transmission seal 1977-1981-1
    1976 Transmission Front Oil Pump Body # 8628912, nos transmission front oil pump body for use on the following models:, Buick 1976 All with M29, Chevrolet 1976 All with M29, Oldsmobile 1976 All with M29, Pontiac 1976 All with M29. $245.00
    Reverse Friction Plate (A24110), Automatic Transmission Reverse Friction Plate (5258017)180, 180C, 3L30 1969-UP 4L30E 1990-UP-2 4.00
    3901119 1964-1969 Camaro Chevelle Chevy II Nova NOS GM Powerglide Clutch 65 66 67 68 230 RS-75.00
    National Oil Seals Seal, Front Transmission ; 6712NA, 5740339, 8626916, 5330-01-025-4212-1 12.00700R4 4L60E TH350 Extension Housing w/o Flange 3932255-1-2.00automatic transmission 5258041 transmission seal 1977-1981-11976 Transmission Front Oil Pump Body NOS # 8628912, New Old Stock From G.M, This new old stock transmission front oil pump body was manufactured by General Motors for use on the following models:, Buick 1976 All with M29, Chevrolet 1976 All with M29, Oldsmobile 1976 All with M29, Pontiac 1976 All with M29. $245.00Reverse Friction Plate (A24110), Automatic Transmission Reverse Friction Plate (5258017)180, 180C, 3L30 1969-UP 4L30E 1990-UP-2 4.003901119 powerglide 1964-1969 Camaro Chevelle Chevy II Nova NOS GM Powerglide Clutch 65 66 67 68 230 RS-75.00
    Turbo Hydro Matic Stator FRONT PUMP COVER - 8628985 / 8628045 / 8630404
    GM 6261448 1969-1971 th350 Turbo Hydramatic intermediate clutch 4.166. 35.00
    gm 8628256 4.256 M-29 Turbo Hydra Matic transmission -200
    GM8628256 GR 4.25
    gm 8653906 8037957 or 8637957 or 8837957 GR 4.22 Hydramatic part
    TH 400 pan and misc gaskets
    GM 3760222 1959-61 Chevrolet Turboglide Automatic Transmission Gasket Set 30.00,have two sets
