Hot Rods GM HEI?
Discussion in 'The Hokey Ass Message Board' started by rusty1, Sep 1, 2019.
  1. Truck64
    Truck64
    from Ioway
    No it works really well. Thermal paste, whether automotive dielectric grease or the bespoke boutique versions aren't really designed to transfer heat as such, what it does is fill in any clearance or gaps.
    It's actually the air space between the components that makes for a great heat insulator. Scuffing the surfaces too before applying it helps quite a bit.
    blowby likes this.
  2. IndigoInkTaco
    IndigoInkTaco
    from Jersey
    I came across this same picture the other day and it was very helpful. I thought this page in general was very helpful in diagnosing my problem. Maybe it'll help others too.
    https://chevythunder.com/hei_troubleshooting_page_2_coil_.htm
  3. 54vicky
    54vicky
    with all the talk about offshore parts lately many years ago(early 80s)trying to eliminate a miss in race engine despite having several spare modules.I said to hell with it and bought a genuine GM it worked miss was a spark plug( CHAMPIAN) that did not spark at high RPM.back to the module imagine my surprise when peeling off the hologram and finding a made in tiawan label.even back then a lot of things were made offshore.does not answer the question just putting it out there with all the brand name part talk.
  4. pprather
    pprather
    I have recently purchased two modules from NAPA. Both are the old four wire type.
    Numbers are
    TP45
    TP45SB
    Both are marked "made in the USA"
    Phil
    scrap metal 48 and blowby like this.
  5. '49 Ford Coupe
    '49 Ford Coupe
  6. rusty1
    rusty1
    ...as a follow up,...after installing the ground strap, everything is working great, thanks for all the posts/help.
    49ratfink likes this.
  7. iwanaflattie
    iwanaflattie
    Im sorry if i highjack the thread...can anyone recommend an aftermarket hei for a centerbolt sbc...im ***uming roller cam?
    Thanks
  8. Kan Kustom
    Kan Kustom
    Thanks
