Technical GM manual transmission oil, GL3 or Sychromesh?
Discussion in 'The Hokey Ass Message Board' started by El Caballo, Jul 19, 2024.
  1. El Caballo
    El Caballo
    from Houston TX
    I’m going to check all of the fluid levels in the 3 speed and rear end of my 1955 Chevy. I have seen GL3 advertised but spendy and on back order, whereas Sychromesh is half the price and readily available. I’ve read where you cannot use GL5 in old transmissions as it affects br***. Has anyone here replaced GL3 with Sychromesh? (No, I’m not going to use trans oil in the rear end.)
  2. gimpyshotrods
    gimpyshotrods
    GL-4 gear oils are fine.
    Syncromesh is fine.
    El Caballo likes this.
  3. SEAAIRE354
    SEAAIRE354
    I’ve been using the Driven GL-4. Says safe for all white metals on the bottle. Not sure on availability.
  4. bobss396
    bobss396
    I run a Richmond GL4 in my M20. One guy I know with a shop swears by Syncromesh. But the ones I have seen do not have GL4 on the label, go with what you know.
  5. Rusty Heaps
    Rusty Heaps
    Tractor Supply carries a GL-1 for older Ford tractors and comes in 1 gallon containers for a reasonable price.
  6. SS327
    SS327
    I always used Red-Line from Summit.
