gm overdrive transmission . what did i buy????
Discussion in 'The Hokey Ass Message Board' started by 32coupedeville, Jul 31, 2011.
  1. 32coupedeville
    32coupedeville
    from cincy
    i bought these two transmissions the other day at a yard sale. now what were they in originaly. here are my questions:
    do you have any info on them?
    do they hold up good behind a sbc under good to moderate driving ?
    is this a t50 ?
    4 speed or 5 speed?
    i have pics of the numbers of the transmissions
  2. oldcarfart
    oldcarfart
    corvette 4+ box?
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    T-50 5 speed OD. Mostly used in 4 cyl and V-6 apps. From a bit of digging some 305 Camero's and Firebirds real early 80s had some. A bit light for much more than a mild 327 etc. driven with any heavy foot. Kinda like running a early Ford 39 style box ,will work driven with a bit of care. Shift pattern is a bit different.
    R 2 4
    L 3 5
  4. 32coupedeville
    32coupedeville
    from cincy
    what do the tag numbers mean?
  5. rustynuts
    rustynuts
    would the t50 replace a 4 spd saginaw?
  6. squirrel
    It looks like a Saginaw as far as the front bolt pattern, shafts, etc. The shifter will probably be in a slightly different place. So it should fit where a saginaw was.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They came in cars that also used Saginaw four speeds, like the Monza/Skyhawk/Sunbird/Firenza type cars.
