GM Positraction ID ?
Discussion in 'The Hokey Ass Message Board' started by blackrat40, Feb 13, 2008.
  1. blackrat40
    blackrat40
    I bought a swap meet GM Posi for my coupe and the seller didn't
    know what kind of car it came out of.It was only tagged as
    "Pont -Olds Posi".
    I need to buy a U-joint and most of the parts guys just give you
    a blank look if you don't know a year and make for the part you
    need.
    So I'm counting on you smart guys to recognize what year and
    make of car I need to buy parts for.
    Hopefully the pic attached will work.
    Thanks in advance for any advice.:cool:
  2. zbuickman
    zbuickman
    60's 8.2 10bolt. Id need more pics for app(springmounts etc.):)
  3. Hi, that's because they need that information to plug into a terminal before "it" will give them a part number. Think of it this way, you call a cab company and ask for a cab. What happens? The guy wants more information like a address...same with with parts, without the info....Anyway - I would take it to a driveshaft shop & they can match a u-joint from what they have in stock & then be able to tell you what you have. Good Luck!
  4. Take the yoke off and take it to the parts store. Tell them its a 1968 Chevelle 307/powerglide car, see if that fits and it should, then get a new pinion seal while you are there also. You will want to put new seals in it anyhow, also new axle seals.:)
  5. zbuickman
    zbuickman
    no it wont.... that would be a Chevy rear than and would be different.... It does look to be a 60's bop 8.2 2 pinnion low 3 high 2's posi. if it has C-clips than Im a dumb*** and listen to the above post
    Edit tell them its in a 65 Pontiac Lemans w/326 3spd man
  6. blackrat40
    blackrat40
    Thanks for the info guys.
  7. dbradley
    dbradley
    Look on the front of the p***enger side axle tube for a stamping. A few letters and numbers. It will be about 3" or so out from the pumpkin.
  8. blackrat40
    blackrat40
    ZBuick,if you're talking about the weird S shaped spring-like gadgets,it
    does not have those. (I have seen those before).
    All I can see is coil springs that seem to be for putting pressure on clutch
    discs.
  9. blackrat40
    blackrat40
    DBradley...thanks,I did not look in that location.
  10. zbuickman
    zbuickman
    No chevy axles were held in with C-clips(inside the diff). BOP axles were retained at the outer bearing with 4 bolts. and the pinnion yolks have different splines between the two. the S shaped spring you mentioned was used in the 70's GM posies.
  11. blackrat40
    blackrat40
    OK,gotcha' on the retainer clips.I don't know if I can see the ends(it's at my shop)
    BTW,I think the tag also said "3.23" so I bet you nailed it.
  12. zbuickman
    zbuickman
    after rereading your post.... you need a u joint????? yeah the u-joint is the same as a chevy. but not much else
  13. clays diff
    clays diff
    the rear end you have there is out of a 67 firebird it is a bop style 28 spline axles no c clips wheel bearings on the axles it has no mounts on top of the housing for trailing arms it is a cone clutch posi if you want a conversion joint borg warner makes one to goe from inside clips what tis has to out side clips like a ford or chev the # is HD9 make sure you a posi additive i use ford in that unit i hope this helps !
  14. blackrat40
    blackrat40
    That is outstanding info there Clays !!!
    Thank you so very much.
    MickeyD
  15. blackrat40
    blackrat40
    Hey Clays...I went to the parts store today to try to get a Borg-
    Warner #HD9 ujoint and they said that was not a good number.
    Do you have any way to check that number you suggested?
    What you said about the rear end like ...no mounts for tr. arms,
    wheel bearings on axles,no c clips...is all correct.
    Thanks for any ideas...MickeyD
  16. testpilot
    testpilot
    from Denver
    looks like 8.5 BOP
  17. slam49
    slam49
    from tulsa ok
    do you have a driveshaft? because the u-joint also has to fit that.
  18. slam49
    slam49
    from tulsa ok
