Technical GM Rear End "ID"
Discussion in 'The Hokey Ass Message Board' started by Ethan Hill, Sep 3, 2018.
  1. Ethan Hill
    Ethan Hill
    from Missouri
    For someone that knows more about rear ends than I.
    The casting number:
    3725899
    With a model number that is E223?
    From what I've read its maybe a 55-64 rear end?
    If someone could confirm or denie this that would be awesome!
    It won't let me get any pictures on here, but its a 10 bolt, with a plug in the back and a slight hump resembling that on a ford 9in. Any help would great! Thanks, Ethan
  2. saltflats
    saltflats
    from Missouri
    E223 would be May 22 1963
    Ethan Hill likes this.
  3. 1934coupe
    1934coupe
    It may be an Olds/Pont. rear. Are the axle tubes oval and tapered? Is the axle flange round and bolt holes wide and narrow (top and bottom width apart) ? A few more pix would be great, also roughly measure size of ham Olds/Pont is about 10+ inches.
    Pat
    After re-reading your post Olds/Pont did not have a fill or drain plug in back. Chev 55-64 would be the next best guess.
  4. Black Panther
    Black Panther
    from SoCal
    Ethan...casting number of the center section confirms that it is a 1955-64 Chevy drop out center rearend. Could have been out of a 1963 Impala or Nova. In looking at the pic...the top bracket and panhard bar mount location look like 1963 Impala..
    saltflats and Ethan Hill like this.
  5. Ethan Hill
    Ethan Hill
    from Missouri
    Thank you for all the replies! Very helpful.
