Projects GM rear end id
Discussion in 'Traditional Hot Rods' started by camcrusher, Feb 23, 2022.
  1. camcrusher
    camcrusher
    from Candor, NY
    Hello, I recently bought a model a hot rod that the previous owner lost interest in. It had a 307 Oldsmobile engine and 700 R ******. However I don't have a clue as to what the rear is other than GM stamped on the ring gear. Any help identifying it would be greatly appreciated. I'll load a few pictures. IMG_20220223_160442086_HDR.jpg IMG_20220223_160733243.jpg IMG_20220223_160741900.jpg
  2. squirrel
    so is 10-41 or 9-38 the date code? or the ratio? :)
    Not chevy, they were closed driveline back then, and also never used that U joint. I'd guess olds/pontiac, but that's just a guess.
    Hnstray and guthriesmith like this.
  3. Wrench97
    Wrench97
    Did the 3/4 ton Chevy trucks use that style joint?
  4. 38Chevy454
    38Chevy454
    Count ring gear teeth. I bet it's 41, which makes the 10-41 indicating 4.10 ratio. The 9-38 may be date code. What is the bolt pattern for the wheels? Chevy were closed drive torque tube back in 38, so agree it may be another GM division like Pontiac or Buick.
  5. squirrel
    I don't think so. Also, the cover bolt pattern is different on the truck in your picture, and the mystery rear end.
  6. camcrusher
    camcrusher
    from Candor, NY
    The lug pattern is 5 on 5.
  7. lippy
    lippy
    from Ks
    Looks like early olds or pontiac, Like 49? Lippy
  8. camcrusher
    camcrusher
    from Candor, NY
    I have a '53 Olds rear end that I'm putting in it and it looks a lot different than this one.
  9. lippy
    lippy
    from Ks
    Your right crusher, they wouldn't have the rear cover I don't think. Lippy
  10. camcrusher
    camcrusher
    from Candor, NY
    Well that helps out a bit. Thanks for all the comments.
  11. squirrel
    I found a pic of a 37 olds rear, it has the separate rear cover, and the same Mechanics type U joint, but the front casting is a different shape. It's a lot closer than anything else I've seen.'
  12. camcrusher
    camcrusher
    from Candor, NY
    Hey squirrel, I just saw a '37 Olds rear on cl***icOldsmobile.com that has the same rear cover and the backing plates are the same as what I have. So it's possible it's a late '30's early '40's Olds rear end. Good to know.
  13. Mr48chev
    20220223_200725.jpg 37/46 Pontiac. The U joint flange jives with 37/38 Pontiac rear U joints
    eBay item number:
    This page out of my 1946 Motor manual.
    230994479312
    guthriesmith likes this.
  14. squirrel
    ribs on the front of the center housing are flat on the Pontiac, angled on the mystery rear. The angled ribs on the mystery one look like later Olds centers.
    mystery:
    later Olds:
  15. Mr48chev
    37/38 Pontiac had that Lock screw 37 38 Pontiac rear.jpg beside the pinion shaft. Olds didn't have that. This being a 37/38 Pontiac third member from an old and long gone Ebay add.
