Technical GM S10 T5 confusion
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Feb 16, 2023.
  1. big duece
    big duece
    from kansas
  2. Duncan71
    Duncan71
    And adapts well using a GM bell housing and and adapter plate - giving you the correct input shaft length. All things I just did, and relied on gimpys expertise to accomplish!
    gimpyshotrods likes this.
  3. 40desoto
    40desoto
    Meant to say on the earlier S10's with the forward shifter location
  4. 40desoto
    40desoto
    Nice! was the tail shaft exchanged for the forward mounted shifter?
    I was under the impression that only the older ones were forward mounted. Now I want a WC for my build [emoji30]
  5. ERguitar
    ERguitar
    Yes they have the same shifter location as a nwc. You won't find one without the electronic speedometer though (unless it's been converted). Easy identifiers are the 27 (memory) spline input shaft and the narrow (ford) bolt pattern. Once you see a nwc and wc side by side the difference is pretty apparent.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The T5 I have from a '93 S10 2.8 is a WC with a Chevy bolt pattern. I.D. tag #1352-222.
  7. gimpyshotrods
    gimpyshotrods
    Need pictures.
    '34 Ratrod likes this.
  8. gimpyshotrods
    gimpyshotrods
    Be careful what you wish for. The WC T5 that appeared in the S10 only came with the 4.03:1 first ge****t.
    40desoto and winduptoy like this.
  9. Truckedup
    Truckedup
    I have a S10 4.3 5 speed 2wd.... Gm specs do not support NV3500 in 92 as it was first intrduced in 93 ....92 should be the German Getrag, HM360 I believe...It looks nearly identical to the Nv3500 The RPO code on the label in the glove box will list the gearbox number....
    Cosmo49 likes this.
  10. gimpyshotrods
    gimpyshotrods
    They are similar in appearance, but are not the same inside.
  11. winduptoy
    winduptoy
  12. Rocky
    Rocky
    Classified Editor
    I had one of these behind the flathead in my old 33 pickup. It came out of a 93 S-10 two wheel drive pickup I drove 'till the rust killed it. The plug behind the counter shaft in the trans housing was not the sheetmetal type in the non WC. it was a machined press-in plug with the big GM bolt pattern. I believe early 93s were the only year to have this trans. Worked great!
    I also put a NWC S-10 trans behind a 406 SBC in my old 50 chevy delivery. It had the 4.03 or the 3.50 low gear which worked great in the car because the rear axle ratio was 2.29. Easy to drive in town and in 4th gear it would loaf along at 75 MPH all day.
    winduptoy and TomT like this.
  13. Hitchhiker
    Hitchhiker
    winduptoy likes this.
  14. gimpyshotrods
    gimpyshotrods
    Had to be trailing-stock.
    Borg Warner shut down the casting run for GM pattern cases, after making the last of the production orders, and service parts in early 1993.
    By then there were so few requests for that combination that they could not justify continuing production.
    Casting aluminum takes more energy than machining steel.
    Ford, on the other hand, was still using the WC T5.
    Same steel base stock, different machining.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Here ya go. 20230218_103834.jpg 20230218_103838.jpg 20230217_184700.jpg 20230217_130854.jpg
  16. hotrodlane
    hotrodlane
    Yep! 1352-222 The one year only 1993 2.8 V6 is the Only S10 T5 that was world cl*** and had the GM Munice bolt pattern. 1993 4 cyllinder S10 transmissions were Worldcl*** but had the ford bolt pattern And all 94-95 s10 T5's had the ford pattern.
  17. gimpyshotrods
    gimpyshotrods
