GM turn signal cancelling.
Discussion in 'The Hokey Ass Message Board' started by 29SX276, Mar 29, 2012.
  1. 29SX276
    29SX276
    I have an early 60's chevy steering column,no ignition switch or gear shift handle. It's a tilt unit and the turn signals won't cancel.I haven't torn it apart until I can find out "how" to take it all apart without screwing something up inside.I found two springs lying at the bottom of the column tilt jacket .How do these springs mount ?
    Any ideas of what's involved ,any good manuals on the subject ? I've attached pics of the unit .
    Thanks gents.
  2. goford51
    goford51
    from griffin ga
    you got to take that little snap ring off the shaft at the horn contac or gold thing and then it should come apart
  3. 40FordGuy
    40FordGuy
    The springs are for the tilt function......You shouldn't have to get into that part, to access the t/sig switch and it's mechanism.
    4TTRUK
