Technical GM universal steer column key/shifter question
Discussion in 'Traditional Customs' started by Sdsurfer01, Aug 31, 2023.
  1. Sdsurfer01
    Sdsurfer01
    Good evening all,
    I got a speedway GM universal steering column with key: https://www.speedwaymotors.com/Univ...ing-Column-With-Shifter-32-Chrome,486001.html
    I started another post on the wiring:
    https://www.jalopyjournal.com/forum...versal-steering-column.1300064/#post-14970078
    but I was installing today and noticed something else….
    I ***umed before I bought it that the column wouldn’t be able to shift unless the key was inserted. Looking for some extra security so it can’t be shifted to neutral and pushed without using a key.
    I was installing the shift linkage today and noticed I was wrong… I can shift through all gears without the key in.
    is there a way to change that in the column so it won’t shift without the key installed?
  2. pprather
    pprather
    You may have to leave the wheels turned hard, as key should lock the steering.
  3. squirrel
    get an old column out of a junkyard instead of the new reproduction ****?
    seems like they did away with the shifter locking feature when they copied the design.
  4. Bandit Billy
    Bandit Billy
    ^^^^This. The Aftermarket columns don't have interlocks that I know of. Either OEM or early ford with the lock in the column drop (not a new idea)
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ve always removed that feture. This is where the locking pin would exit. C141799F-598F-4E0C-A9CA-39F2FF17CFEC.jpeg
    But that’s not the end of it. It would need the locking plate as well. 8F11B0DB-5BC5-4E84-ACC4-276F64E9B54E.jpeg
  6. Sdsurfer01
    Sdsurfer01
    I just checked this morning and I can turn the front wheels without the key in so I may try to return to speedway motors. Doesn’t seem worth it to finish installing when it provides nothing new for security compared to my old column without the key.
    Thank you all for the information
  7. Budget36
    Budget36
    I went to the link you posted, I kept drilling down for details/etc. it made no mention of a lock.
    But one thing I read was “we made this….” So this makes me think they spec’ed it out? I’d call first and ask if it can be retrofitted with the locking setup.
    To be honest with you, if I sold a product and listed every feature the product had, someone buys it and then wants to return it because it didn’t have a feature they wanted, I’d have a hard time accepting a return.
    But they are a large company, so the person on the phone may not be concerned with that and just say “send it back”.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Do you really think the steering wheel lock is a deterrent? If they want it, they’ll get it.
  9. If you have an original column but no key just take it to a locksmith. He can get the cylinder out then you can just buy a new cylinder at the autoparts. They are not pricey.
    This will make someone chuckle. I had an OT mini truck (I still have the 355 that I put in it). My insurance agent told me that they would not insure it unless I put an external steer wheel lock on it. So I bought a Club. A couple weeks back I was looking for a distributer and found my Club complete with key. It must be an omen. :D the club.jpg
  10. goldmountain
    goldmountain
    The OEM columns that locked were the ones that had the shifter integrated with the steering column. The ones that had a separate shifter such as 4 speed trucks and small cars did not have the locking column feature but included a small push tab that you needed to engage before taking out the key. This was to prevent the problems you would have if you inadvertently locked the column with the car still in motion. The aftermarket columns just didn't want to deal with insurance complications.
  11. 325w
    325w
    You can get the tumbler out of the locking column by removing the lock ring. Depress a tab and pull the tumbler right out.
  12. 1971BB427
    1971BB427
    from Oregon
    Doesn't that only lock the steering, not the shifter?
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes.
    Went back and read the opening. Well, I’ve said it before here, I don’t read very well. Been that way my whole life. Couple that with other replies and bam, I’m back in the corner of the cl*** room facing the wall.
    That said, who really want’s to wire in a release solenoid to the shifter from the brake pedal switch once the ignition switched is turned to the on position and or vehicle started? But that would mean Speedway column is just fine then. Yes, no, maybe?
  14. 1971BB427
    1971BB427
    from Oregon
    Not me! I'm just fine with my shifter not being affected by my ignition key. I do like my steering locked when I remove the key, and that's how my '39 column is.
  15. Sdsurfer01
    Sdsurfer01
    Update:
    I ended up ordering another column without the key in it. Yeah I agree, it only gives a slight, if any, additional security. Plus not worth all the extra h***le.
    I’ll call speedway and see what they say on the return, probably won’t accept as I installed it and not exactly new anymore. I’ll probably end up posting it for sale locally and see if anyone’s interested and then when no one buys it, I’ll forget all about it for like 10 years then try to install it again and remember why I didn’t in the first place…
    pprather likes this.
