GM ZZ383 crate engine?
Discussion in 'The Hokey Ass Message Board' started by tattoochucky, Oct 20, 2007.
  1. tattoochucky
    tattoochucky
    from ventura ca
    Does anyone have info on the ZZ383 425 crate engine, dyno results, 1-4 mile times with combinations rear end gear ratio, tire size, trans., ect. I don't need to know about olds engines or other bull!If you have built a 383 that puts out 425 hp or more with less than 10 to 1 compression for less than 5,000 dollars by using all new parts, post your combination, parts used, specs!If you havent had your motor dynoed dont bother, I need facts not a estimate!
  2. Choptop
    Choptop
    I'm interested as well. Considering one for my upcoming 63 Burban project that needs to be done pretty quickly.
    anyone?
  3. mrbelair
    mrbelair
    from holland
    A friend of mine runs a ZZ383 in his '55 Delray.
    The car goes 11.9 with 4.10 gears, picking up a frontwheel.
    325-50/15 MT ET street radial tires
    The engine likes pumpgas and is very streetable!
    www.chevyracing.nl
  4. check out Hot Rod magazine.
    They have done extensive coverage /testing of this engine.
  5. The current issue of Popular Hot Rodding has an article on a ZZ4 (350 355hp) that they take to over 400hp and there is a list of parts.
  6. HotRodMicky
    HotRodMicky
    What is the parts number and where to get them cheap?
    TIA
    Michael
