Hot Rods GMC 302 high dollar build. Chipped pushrod and cracked rocker support
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Aug 31, 2014.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    I bought a gmc 302 that was a high dollar build from Fresno California. It has changed hands a few times but was originally built by Joe Bogosian I am told. I took the valve cover off and there is a chipped pushrod on the end. They are obviously aftermarket and i need to replace it. Where do I find one that matches. I can remove it to measure length. Also, I am not sure you can see it in the pic, but the rocker shaft IMG_0832.JPG supports on this engine are cast aluminum (all of my other gmc 302's have stamped steel one and the one on this engine with the oil tube coming out of it is stamped steel) and this one pictured has a crack running up it. Should I just replace it with one of my stamped steel ones? Replace them all with my stamped steel ones out of another engine I have?
  2. flying53gmc
    flying53gmc
    from M-boro, TN
  3. flying53gmc
    flying53gmc
    from M-boro, TN
    ImageUploadedByH.A.M.B.1409523679.463520.jpg ImageUploadedByH.A.M.B.1409523699.610047.jpg
  4. RichFox
    RichFox
    It looks like more than one chipped pushrod end. I bought mine from Smith Bros. They were an insert in either end of a 3/8th tube. Worked fine with the stock rocker adjusters and never "chipped". I also always ran the steel stamper stands and if I were you I would go with them. I saw some of the cast aluminum stands. Think they were from an early version 220-270 type motor. Looked cool but I never used them. Ran mine for years on the salt, at the dirt and a few times at the strip. Smith Bros. PS I never put a lock washer against aluminum.
  5. Fitty Toomuch
    Fitty Toomuch
    from WVa
    I`d be worried where all that metal went.
  6. flying53gmc
    flying53gmc
    from M-boro, TN
    Hey Rich, I was hoping you would see this. I will replace them with my steel ones. Not sure what the valves or cam is but there are 2 valve springs on each valve. I guessing I don't need to use a stock pushrod, right? Also, what are the two wires on the HEI distributor? Tach? 12v power?
  7. over the years I learned the old adage that most times you have valve train damage you have too weak valve springs has too often been revealed to be true. Damage comes from separation of parts and their remeeting at higher RPM.
    I used manton for custom pushrods.
    don
  8. Ebbsspeed
    Ebbsspeed
    Are you sure that's a crack and not just a casting line? Maybe I'm not seeing the crack you're referring to....
    falcongeorge likes this.
  9. harpo1313
    harpo1313
    from wareham,ma
    The crack appears to be from over tightning .
  10. saltflats
    saltflats
    from Missouri
    The wires out of the dist would go to the coil.
  11. RichFox
    RichFox
    As far as the pushrods go, I am sure you are right. But they do look as though some one may have skipped the draw part of a two part heat treat.
  12. Babyearl
    Babyearl
  13. David_396
    David_396
    Was this motor in a early Nova before you purchased it?
  14. Stovebolt
    Stovebolt
    I cannot add anything else than what the others have said about the issues with your engine.
    I was only just looking at your coupe project thread. What I can say about your project is - has there been any progress since your last post in July 2013
  15. flying53gmc
    flying53gmc
    from M-boro, TN
    No, a Henry J in Fresno, Cal
  16. flying53gmc
    flying53gmc
    from M-boro, TN
    Sadly, not much. chopped down my windshield, made headlight bar and shock mounts. This engine is going to get me re-energized to get going again.
