Features Gmc blowers
Discussion in 'Traditional Hot Rods' started by coopsdaddy, Sep 1, 2012.
  1. falcongeorge
    falcongeorge
    from BC
    In the one carb shot it looked like it was pulling fuel from the shooters at high rpm, so its probably way fat at high rpm.
  2. Kustom Dick
    Kustom Dick
    from Finland
    My 284cid with 4-71
    Deuces likes this.
  3. coopsdaddy
    coopsdaddy
    from oklahoma
  4. fenderless
    fenderless
    from Norway
    Thanks Paul:) We have just started to uppgrade the pakage:)
    New raised inntake with almost equal length runners, and port nozzles.
    New set of really thick Baron Heads:)
    Taildragger&fenderless
  5. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    I went with a 6-71 Mooneyham because I wanted an old looking new blower with no names cast into the case or end plates and they have been around since the 60's. They were able to build me just want I wanted for my blown 392 Hemi, old school looking with all new parts that make's tons of HP!
  6. coopsdaddy
    coopsdaddy
    from oklahoma
    Lets see some more!
  7. Dean Lowe
    Dean Lowe
    Exactly why I got my 6-71 from Gene. Plus, why would you not want a blower from a legend!!
  8. Morrisman
    Morrisman
    from England
    I have a 6V71 that I plan to use some day. It is a base model straight off a diesel motor, but obviously needs some work doing. It'll be fun. I plan V belt drive, not toothed belt.
    Deuces likes this.
  9. 8thdaycr8
    8thdaycr8
    Just in mock up stage right now. At least I found an original Ronco/Vertex magneto for this 270.
    Deuces likes this.
  10. Gassy
    Gassy
    from Tennessee
    Here are a couple sitting around.
      180.1 KB
      138.2 KB
    Deuces likes this.
  11. Deuces
    Deuces
  12. Fatbrosracing
    Fatbrosracing
    from Australia
    Mine, GM case, locally produced end plates and drive.
  13. coopsdaddy
    coopsdaddy
    from oklahoma
    What's the lowest setup on a 671 with dual carbs,what's the minimum thickness of carb plate? What about low profile air cleaners?
  14. deuce354
    deuce354
    No to be picky, but they are not GMC blowers , they are GM blowers. The GM means Gray Marine
  15. Depends , my hemi blower manifold is an old weiand piece and the base if the blower is even with top of head bottom of valve cover. I forget the numbers but i have heard it called a typhoon manifold before. That's realky low compared to some.
    Carb plates are generally less than an inch, I have some 7/8" and 3/4 inch. The 7/8 looks better.
    Offy made some adapters that held the carbs low & over the valve covers.
    Air cleaners, you could get a cobra type or style that setts on 2 4s that's pretty low
  16. Bashnscratch
    Bashnscratch
  17. coopsdaddy
    coopsdaddy
    from oklahoma
    471 with 3 97s or 671 and 2 4s on a built 327, which one and what kind of number can be expected,thanks
  18. falcongeorge
    falcongeorge
    from BC
    Love those 4-71 2 hole hilborns.
  19. :d...
    1947knuck and Deuces like this.
  20. madmak95
    madmak95
    Here's a 4/71 I have mocked up on my 331 hemi for a '34 ford truck im building.
  21. Last edited: Oct 25, 2012
  22. cb1
    cb1
    from Wisconsin
    Here is a picture of my 4-71....
    1950 Allis Chalmers with a Detroit Diesel.
    Grey Marine---Really????
    cb1
    Deuces likes this.
  23. You have it backwards , the Detroit Co , division of General Motors Company Aka GMC, built the first 6-71 in about 1938.
    They produced them by the thousands during WWII for trucks , tanks , gen sets, and boats.
    The Grey co marinized the 6-71 engines in a variety of configurations for the military , and later for civilian boat use
    No- this is incorrect !
    You can delete this misinformation by editing your post- go advanced - delete this message
  24. Salt Racer
    Salt Racer
    from Ft Worth
    Here is a fresh 354 for sale
    Deuces likes this.
  25. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    My new Hampton 6-71 finally arrived today, had to sit it on the 377 just because....
    Deuces likes this.
  26. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Drive ***embly done
    Deuces likes this.
  27. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Getting closer...
    Deuces likes this.
  28. This is my coupe with a V6-71 top of a SBC 360
    Deuces likes this.
  29. Steve!
    Steve!
    from at the gym
    Lets see some more Jimmy blowers!
  30. hog mtn dave
    hog mtn dave
    This is a Weiand street blower we ran about 12 - 13 years ago. Non stripped but run an alky, overdriven, on a very low compression 454 . Still ran 185 mph. Never expected that. Blowers are cool. Never should have sold that piece.
    Deuces likes this.
