Technical GMC Inline 6 starter options
Discussion in 'The Hokey Ass Message Board' started by Devin, Jan 19, 2023.
  1. Devin
    Devin
    from Napa, CA
    As much as I’d like to keep the stomp starter on my 270, I don’t think there’s enough room between the bel housing and firewall. What options exist for starters using a solenoid starter? Thanks
  2. iwanaflattie
    iwanaflattie
    I have a starter on a 270 that doesn't have the stomp starter.
    I have to pull check the number
  3. iwanaflattie
    iwanaflattie
    Delco remy
    6 B 9
    Bob Lowry likes this.
  4. Gofannon
    Gofannon
    Mini starters are available. Is your original starter 6v or 12v?
    firstinsteele likes this.
  5. Mr48chev
  6. jimmy six
    jimmy six
    You could have a 168 or 139 tooth ring gear. I always used the 139’s. For years I used starters from 53 Chevrolets. They were 6 volt I used on 12. 20 years ago I had a shop build 2 adapters to use the mini. The Hitachi actually came stock with the right gear for the 139 tooth. They turner over the engine fast than the later starters.
    Now with a Buffalo engine plate and a 168 tooth flywheel I use the bolt up minis.
  7. Devin
    Devin
    from Napa, CA
    Wow! Excellent information. Thanks gents!
