Go carts ok? Indy styled go cart rebuild
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, Dec 20, 2024.
  1. Plastic was busted in several places.
    1/2 a wing missing. Unknown plastic. So we improvised.
  2. Students made patterns and we bent the spoilers at our HVAC cl***.
  3. I like it. Do you have a plan?
    Sharpone and Deuces like this.
  4. It’s a project at school. Plan it to get that thing gone. Supposed to be a Christmas present. The owner has had issues getting parts. It might not be completely functional by the 25th but it will look cool. Santa has has a parts chain issue this year.
  5. Body was busted and missing a couple chunks. We found out an ABS plastic welding rod stuck to it. We have a nitrogen plastic welder and fired it up. For the back side we used staples to s***ch up the cracks. Tool looks like this
    used parts of the original wing to weld back into the body. Even heated and contoured them to fit
  6. After that we used panel bond as a filler material.
    Our first try failed due to a product issue. **** didn’t set up. Cost us a few days but we finally got primer on it
  7. Also had to straighten the frame
    right side wheel was about 3/8 back as well.
  8. Added some structure on the front to mount a skid plate to protect the front
    The visible parts of the frame are blue. The rest is black for EZ touch up.
  9. Our booth is down so we shot it where the old “booth” used to be. A curtain and a roof vent
    Old school wet the floor and shoot.
    The wings drying in the cl***room. It has better heat.
  10. This is where it’s is now.
    Owner has more parts coming. Still have to finalize the pedals
    Originally had some kind of hand controls. I’ve never seen em. So we welded some mounts for pedals in the frame.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Someone is going to be over the moon, when I was a kid my grand dad built me a bicycle from parts he scrounged at the dump, it wasn't new or perfect but I was the happiest kid in the neighborhood that Christmas. HRP
  12. Yep. Can’t hardly imagine waking up to this
    It’s got some odd ball pieces I hope the guy can find. Never seen a go cart like this.
    Here is the drive sprocket
    the single drum mounts the this plastic sprocket
    The sprocket slides into webbing on the back side of the wheel. The thin slots.
  13. Slides into this
    here’s the set up together
  14. Engine choice???
    porkshop, Sharpone and Deuces like this.
  15. Never mind. I was ahead of your post. :)
    porkshop, Sharpone and anthony myrick like this.
  16. SS327
    SS327
    Parts for those are made from unobtainium. They were promo karts never really sold retail. Best bet is to convert it to a 1” axle and 30 series CVT TAV II. Get rid of the plastic rims too.
    bchctybob, porkshop, 29A-V8 and 2 others like this.
  17. Never a dull moment in Mr Myrick’s cl***, Merry quick Christmas to somebody…
    Deuces, Okie Pete, bchctybob and 4 others like this.
  18. Makes sence. The plastic had ***mins Diesel decals sun faded into it
  19. SS327
    SS327
    A GoKart site I’m on we get people all the time looking for parts for those and there just aren’t any. But atleast he got an early model with the steel tube frame. (A good one) The later plastic pan/frame is total junk.
    Deuces, bchctybob, porkshop and 2 others like this.
  20. RodStRace
    RodStRace
    That's a rabbit hole I've peered into a couple times. The later vans, and prowler miniatures. They are out there, but you gotta beat the bushes and have the funds ready to go when one turns up.
    As said a lot of them with the bodies were promos, little billboards to sell stuff.
    If you have searched for parts, this place is probably the most easily found.
    https://gokartsusa.com/Gokarts-With-Car-and-Truck-Body.aspx
    Deuces, Okie Pete, bchctybob and 5 others like this.
  21. Sharpone
    Sharpone
    WOW, if had received something like this for Christmas WOW how do you top that.
    Good ,no,GREAT stuff Anthony
    Dan
  22. ottersea
    ottersea
    Kool stuff. Always interested but never got into it. I always dreamed of something like this but life got in the way. This was from mid 80's but still slick. They were gettin lap times as fast as the nascar guy would. img658.jpg
  23. We got it this far.
    The tubes for the tires and a couple other issues have knocked out the Christmas deal.
    so the dad has a plan B ready.
  24. Got the pedals figured out. They adjust and so does the cable bout with the gas pedal
    The brake rod can be shortened or lengthened as needed
  25. SS327
    SS327
    Not to be a **** but those are MANCO styled pedals. They are on backwards (on the wrong sides). They were made that way to keep your foot from sliding off the pedals. Looks great otherwise.
    deathrowdave and anthony myrick like this.
  26. Hang on. Just looked at the pic. I’ll swap em around when we get back on it :)
    I’ll probably straighten em out some and ad a piece to keep the foot from slipping
    Deuces, bchctybob, Sharpone and 3 others like this.
  27. Here’s the brake rod IMG_3970.jpeg IMG_3969.jpeg set up
