Go fast gears for 34 ford?
Discussion in 'The Hokey Ass Message Board' started by Preikster, May 1, 2007.
  1. Preikster
    Preikster
    from sk, canada
    Just picked up a bone stock 34 sedan. For an untouched original car I am pretty impressed. The only concern I have is that the old flatty seems to be buzzing hard at 50 mph. I see many aftermarket gear ratio options for 35-48 rears but nothing for the earlier stuff. Are lower numerical ratios available for the earlier rear ends? The car is original and I don't want to modify it too much... I do plan the standard improvements such as hydraulics but would like to keep the stock rear. What are my options?
    - Craig
  2. VAPHEAD
    VAPHEAD
    I sell new 3.54 gears for the 34.
    Shoot me a PM.
  3. Ken Smith
    Ken Smith
    Alliance Vendor
    The reproduction 3.54:1 ring and pinions are made for the 35-48 rear ends. The pinion can be modified to fit the 34 center section. Some suppliers offer them already modified with a pinion nut spacer. Either way, the drive shaft will have to me shortened and fitted with a 6 spline coupler.
  4. Bruce Lancaster
    Bruce Lancaster
    3.54's, easy install brake cylinder setup from early V8 garage, adjust steering play. done!
  5. Preikster
    Preikster
    from sk, canada
    Are the 3.54 ring and pinions sold as 32-34's actually modified 35-48's?... ie) Do the reproduction 32-34 require the coupler/driveshaft shortened or are they direct replacements?
  6. Preikster
    Preikster
    from sk, canada
    That is exactly what I have planned. The tires are 40 years old so I am going to run some 16" wires or solids (not sure yet). Probably add a dropped axle also.
