Projects Going Gasser....Maybe?
Discussion in 'The Hokey Ass Message Board' started by FunnyCar65, Aug 13, 2009.
  1. Big Dad
    Big Dad
    What we have here...is a failure to find a plymouth. :D I like your avatar. Lippy[/QUOTE]
    working on it dude ..
    I have missed a couple already but I'll find one
    color , what color should it be .. Thats a big debate in my mush of a melon
  2. and survey says; "Do It To It" & have fun!
  3. cheezwiz
    cheezwiz
    O.K. if you guys are gonna beat this dead horse then I'll post my revised photochop from last night !!
  4. Animal
    Animal
    Well, I'm biased, but I do really like the 56 Mopars, and I definitely like them with radiused wheelwells. My '56 Plymouth wasn't a "g***er" but I called it g***er-inspired, because as a kid in the 50's and 60's those were the cars that tripped my trigger. Mostly tri-5 Chevies, but I dig the first year of fins on the '56 Mopars. And they're definitely not as common as Camaros!:D And a 440 looks good in there!
  5. rob-redm
    rob-redm
    once you go g***er, you never go back !
  6. FunnyCar65
    FunnyCar65
    from Colorado
    I like the front moved forward a little.The rear looks bad*** also I'm just not in the mood for that much surgery on another project.I think with a nose bleed stance the wheels moved up a little helps the look,a lot of cars look like the frontend is to far back when you try and keep it centered in the front wheel opening.
  7. bbc 1957 gasser
    bbc 1957 gasser
    i like the green one. but you need to push the back wheels forward on it. it just looks out of place ..imo
  8. DirtyThirty
    DirtyThirty
    from nowhere...
    It DOES look bad-*** with the rear wheels right under the post...:cool:
    AWB is good too...
    Its a cool looking car, and FAR from ordinary, I don't think you can make a wrong turn either way, unless its got a slant-six in it...
    Unless...of course, its got one NASTY Slant-six...which actually would be kinda cool.
  9. edweird
    edweird
    i need to live in your area. nobody here even knows what a g***er is. that ****s!!
  10. FunnyCar65
    FunnyCar65
    from Colorado
    What I got figured out so far is. Speedway straight axle kit with discs.I have a pair of 16x11 Americans I'll see if Cody at Hurst can do a 16x12x30 Pie crust.Big block with a Weiand Drag Star 6x2, automatic and a 8-3/4 I haven't decided on gear ratio yet,I want street drive it.I need to find I pair of front wheels and figure out the interior,what would be correct interior wise? Any interior shots I can get a look at?
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Copy the interior straight from the Suicde King, except replace everthing gold with green.
  12. curbspeed
    curbspeed
    I would suggest raising the rear wheel opening with the stock lip. I think that would look right.
  13. Falcon Gasser
    Falcon Gasser
    I would go with the straight axle look, you just doent see that many Chrysler straight axle g***er/altered looking cars.
    Jon
  14. Gasser57
    Gasser57
    Well said! Never seems to sink in on this site, though. I'm in Ohio, always has been, and still is saturated with g***ers. Have yet to see these 6 cylinder, underpowered faux g***ers that every expert claims is roaming the streets , losing races to Chevettes with a fouled spark plug. At the same time, if a guy follows the suggestions of the HAMB m***es and runs a small hemi or a poly, and a set of deuces on top and some pie crust slicks, these things will all increase the cool factor, but hurt his E.T.'s compared to more modern racing equipment like a 440, dominator and modern slicks.
    It's a cool car, if you choose to build a g***er styled car out of it, it will surely be a blast, especially because it's different.
  15. kraka138
    kraka138
    i think you should go freakier
  16. DirtyThirty
    DirtyThirty
    from nowhere...
    WoW! Did a Falcon knock up a Sneaker?
    That is REALLY weird...
  17. Prostreet32
    Prostreet32
    from Indy
    Put it up in the nose-bleed areana,..stick a potent big-block in it,..fender well headers,..and scare the hell outta all your community folks...LOL.
  18. Prostreet32
    Prostreet32
    from Indy
    I'd do a late 50's theme on the interior
  19. badnews 31
    badnews 31
    g***er it man!!!!!!
  20. JeremyJames
    JeremyJames
    from concord NC
    my vote is for the g***er!
