Hot Rods Going the extra mile for a period correct build
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jul 24, 2020.
  1. lippy
    lippy
    from Ks
    Maybe you could do as Mark said and put a newer compressor right up top in the middle and fabb up a tight fitting cover for it and paint and pinstripe it. Maybe? See, I can be constructive at times, :D Lippy
    Roothawg likes this.
  2. Boatmark
    Boatmark
    I'm not sure I understand this "correct" term. We are talking about Hot Rod's, which by definition is a car modified for performance or looks to meet the owners needs or desires. So I define what is "correct" for my car. It's often the most vocal about the period correct rules who define their cars as "period correct, except for . . . . ". If you are going to comment on what is "wrong" with another's choices, yours should be pure beyond reproach. Few are. I love when someone tells me something is "wrong" on my car. Nope, nothing wrong with the car. Might be something wrong with you.
    I also agree with Jnaki's post about accuracy of period correct. A lot of cars billed as period correct are in fact of mish mash of different periods of old.
    Live by the Jim Croce motto: If you dig it, do it. If you dig it a lot, do it twice!
  3. Callmaker
    Callmaker
    Rock on Boatmark
  4. ramblin dan
    ramblin dan
    Maybe it's just me but when I go to a car show and see an air unit in a car I tend to think more about the work that went into putting it in than being of a certain period in hot rodding. Sometimes I look at old hot rod books and wonder if these guys who built them back in the day them would have used these modern updates had they been available to them at the time or the guys that bought brand new cars and took them in to be customized back then.
    Roothawg and 210superair like this.
  5. Arominus
    Arominus
    I lucked out and scored a factory in dash A/C setup, I’ll be running a sanden on 134A, but I’m tucking it in on the bottom of the motor so it’s less visible.
  6. Roothawg
    Roothawg
    So, after looking at Mark's 40 it appears that I need a vintage, chrome air compressor that measures somewhere around 2" x 3". :D
  7. lippy
    lippy
    from Ks
    That should be easy to findo_O LOL
    31hotrodguy and Roothawg like this.
  8. BamaMav
    BamaMav
    from Berry, AL
    Some of the old York/Te***seh compressors were bare aluminum that could be polished up nicely. But they are big, bulky units and about impossible to hide, so they'd need to be up top.
    I'd just use a chrome Sanden style up top and make it a focal point instead of trying to hide it.
  9. TrailerTrashToo
    TrailerTrashToo
    York/Te***seh compressors are called paint shakers down here.
  10. Roothawg
    Roothawg
    Looks like I may just have to fall under the "Traditionally styled" category. I'm afraid I wouldn't make a very good numbers matching resto guy. Can't fault a guy for trying.
  11. I'm sure they did, but they also likely dropped dead in the heat at a higher rate than today...
    Yesterday I went on a cruise in my non-AC avatar. Temps got into the low 90s which around here is very hot. The afternoon drive back was miserable, and both myself and my GF needed cold showers when we got home to get our core temps back down... not a healthy thing. Us PNW people just aren't acclimated to these temps, although one member whose GF is from Arizona, she thought it was great (she wears a coat when temps here are in the mid-70s, it was the very first time I've seen her in a t-shirt... LOL). Sure, when I was younger I could tough it through but it's getting increasingly hard to do that. But with all that said...
    I've never seen a AC install on a 'trad' car that didn't look 'added on', factory or not. The York and Te***seh compressors used in those days were too large to conceal, most compressor brackets looked a bit crudely home-made (even when they weren't), and the under-dash units rarely meshed style-wise with the interior. I see the newer Sanden compressors as an improvement as you at least have a shot at hiding one, although it will be challenging on any pre-50s car. Switching from front to side motor mounts will be a step in the right direction, but I think you'd have to plan the build around the AC. And not to ruffle feathers, but I can't recall seeing even one in-dash install that at the end of the day really looked like it belonged there. The 'generic' dash vents sold by the aftermarket vendors don't help with that.
    I don't think it's impossible to do a AC install on older cars, but some of the premises need to be re-thought IMO. In-dash vents could be forgone with, using the heater/defrost vents will accomplish much the same function, which at the end of the day is to reduce the in-car temp, not just blow cold air onto you.
    Roothawg and Moriarity like this.
  12. krylon32
    krylon32
    from Nebraska
    Been doing this since 1970 and built a lot of kinda period correct cars without air. Of the 5 hot rods I currently own only one has air and I drive the non air cars very little. I just finished updating my 40 standard coupe. My main concern was keeping the exterior looking stock. Already had a 327/350/8 inch drive train. I updated the rear suspension for a better ride, added power boosted front disc brakes for better stopping, added a new 525 box for better steering, anti roll bars F&R for stability, Newport wiper system, cruise control for easier long distance driving and finally air using Bills brackets under the hood with hidden hoses and the Vintage air unit tucked discretely up under the dash, all the controls using the stock in dash 40 knobs. Traditional, period correct, hell no but it's been updated so at 75 years old I can enjoy it and it still looks stock from the outside. I'll build my next Flathead powered car more (Period Correct)???????????????????
    rod1, pprather, PONTNAK123 and 5 others like this.
  13. olscrounger
    olscrounger
    ^^Agree with this-at 77 I like the comfort-have done many 40's as mentioned by krylon 32
    TrailerTrashToo and Gman0046 like this.
  14. Roothawg
    Roothawg
    The truck in question is my “keeper” truck. It will never be sold, as long as I live. My dad bought it for my second birthday. I have struggled with what to do to make myself happy. I have a 390 Caddy slated for it, but I have been pondering throwing a tri-powered 327 in it that I own.
    It came out of my father in laws Chevy pu. It will have the heads on it that my dad set a national record with. It would be a combination of her dad and mine. My FIL p***ed away 3 years ago and it would kinda be cool to honor him by putting his old motor in my keeper hot rod.
    I can put the Caddy in a period correct roadster. They don’t need air....
    Tman and 31hotrodguy like this.
  15. olscrounger
    olscrounger
  16. adam401
    adam401
    In regards to the AC, I wonder if just the complete factory set up from an early car with some modified lines to fit your application would suite your needs? Like in the late 50s you junkyarded an AC setup and fit it to your hotrod. Im not sure. When Was the first AC an option? Might be a neat project. Might be a super pain in the *** haha. Just an idea good luck.
    Edit..... I just googled it and it says Packard had AC in 1940. Im picturing like a black laquer compressor that looks neat but who knows
  17. Atwater Mike
    Atwater Mike
    My O.T. car got its A/C refreshed ('O' rings, rec./drier, recharge) by me last weekend. Ahhh, relief in our 102* days 5 in a row.
    But my '55 F100 is my former shop truck, as well as support vehicle for the old Street legal A/G roadster we ran at Fremont ('Baylands' back then)
    Same truck, still make local runs, a 'regular' at Eagle Field.
    SBC, 350TH, 9" ****. Dependable.
    But the A/C unit on the Chev exhaust manifold bracket has been converted to an air compressor for those 'Service Calls'...and truck still looks like a nice, hot-rodded F100.
    Sooo...Now I'm 77, and the Off Topic Merci-Bz has begun to rile my truck:
    F100 scowls at the pretty, white 2-seat 300SL Roadster in the car port. My fault... When the needle goes above the 90* mark, I head for the A/C model.
    Compressed air on the truck is not something I'd remove, but another compressor? For air conditioning? On the SAME ENGINE? Dual compressors?
    Nope. Not even COOL.:cool:
  18. AC was generally rare as factory installs until the late 60s. Most OEMs didn't even offer it until the mid 50s and even then most were just repackaged aftermarket units. One thing that accelerated 'integrated' AC was when the factory's started deleting vent windows and compensated by starting to install in-dash vents. Once the vents were in place, it wasn't much of a leap to add AC.
  19. 41 GMC K-18
    41 GMC K-18
    Proper spelling for a complicated name.
  20. olscrounger
    olscrounger
    1st I recall was my grandparents new Cadillac-maybe 53 then my grandmothers 56 Chevy with factory air. Didn't see too many though. Neighbors 57 Nomad is a factory air car as well.
    41 GMC K-18 and Roothawg like this.
  21. seb fontana
    seb fontana
    from ct
    Drive the compressor off the driveshaft, don't stop.
  22. Roothawg
    Roothawg
    I'll be ok with a Sanden 508 if I tell myself it's not a period correct build.
  23. K13
    K13
    Are you changing your transmission plans? If not it's not period correct anyways AC or not.
    ffr1222k likes this.
  24. 6sally6
    6sally6
    Hey Roothawg.......can't you mount the compressor on the driveshaft? I never done it but why wouldn't it work?
    Granted....when you're stopped it ain't cool'in but when you are ...........:).
    Looks like a lot of the "don't-do-its" are coming from fellas that HAVE AC(in their early 60's/late 50's) or they live in a cooler climate. (some places it really DOES cool off some at night....or so I've heard.....but not OK or SC.!) Then those fellas that talk about their...."dry heat"! Yeah right.
    You're/I'm too damn old to sweat our ****s off so we can proudly state....."see it's totally period correct!"
    Bet theirs don't run 100 octane gas like back in the day/good old non detergent oil like back in the day/road tube(no pcv) like back in the day........and on and on!
    Jus say'in
    6sally6
  25. Roothawg
    Roothawg
    No. I don't want the Caddy transmission. Expensive and temperamental. Any other ****** would probably get shredded. Early Ford? Nah?
  26. SOOOOOOOO much history with the 327. Total tribute car all the way around, but tributes to people YOU care about.
  27. partsdawg
    partsdawg
    from Minnesota
    1955 Mercury’s had a trunk mounted A/C unit as a accessory. Traditional.
  28. That's where the factory air on my '56 DeSoto is also. Looong AC lines...
  29. Cosmo49
    Cosmo49
    OMG, LMAO!!
  30. C Corso
    C Corso
    There have been alternators driven of of the axle pinion. Maybe you could do the same with a compressor and hide it in the trunk.
