Going to UN-r*t the Rod,27 chrysler rebuild
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Feb 13, 2010.
  1. rottenleonard
    rottenleonard
    O.K. Boyd here's your update:D
    After two tries(the first shot I couldn't have gotten more dirt in it with a shovel)It's kind of a custom mix of colors from some alkyloid enamel that I had and some of the same that I had mixed up but didn't like the shade with a little of this a little of that and a lot of the other I found a shade I liked and added some gloss modifier to dull it a little.
  2. James D
    James D
    I salute you. Looks great.
  3. hey. it wasnt that ratty to begin with...
    But the new paint and body work looks great!
  4. gnichols
    gnichols
    from Tampa, FL
    Neat stuff. The Phoenix is rising. Gary
  5. rottenleonard
    rottenleonard
    The new front wheels just showed up to, I'm a little torn on front tires, Love the bias ply look but I sick of bouncing all over the road
  6. What makes you think its a chrysler? It looks like a Buick, a pontiac, or an international truck to me.
  7. Hotrod95
    Hotrod95
    Dude! Thats awsome!
  8. rottenleonard
    rottenleonard
    The body is a chrysler 210 doctors coupe, but the grill is a shortened international truck grill
  9. rottenleonard
    rottenleonard
    When I built it thats what rat rods were(hot rods without the fit and finish) But now it's changed into shock factor **** without anything truly interesting.
  10. ratster
    ratster
  11. Louver Dude
    Louver Dude
    Man I hope this is a new trend !!!! LOL keep up the good work, I would love to see more pics of your tracer . Thanks Louver Dude
  12. rottenleonard
    rottenleonard
  13. wood470
    wood470
    Don t ya think thts gonna take alot of the fun outta the car?
  14. Django
    Django
    from Chicago
    I like where you're going with the car.
    The Photochop looks great too.
  15. dartracer
    dartracer
    Great redo. Kool factors coming on strong.
  16. bct
    bct
    you could do a tech on your door frame and i would vote for it too!
  17. chris55
    chris55
    X2 on the door frame tech.
  18. Shagrat
    Shagrat
    Love that color on it! Are you still going to make a lift off hard top?
  19. rottenleonard
    rottenleonard
    Oh yea, I'm going to get it going as a roadster as fast as I can so I can drive it this summer(and to get rid of the piles of parts laying around the shop) and then work on the coupe doors(they will be a little more involved)and roof.
    The comments really are a motivator. Thanks Robert
  20. rottenleonard
    rottenleonard
    Well time for a BIG update!!!!
    I did some re***embly the last few weeks, nothing to brag about just bolting back together so I didn't take any progress pics just final results(at least curently) I'm Realy liking it It has taken on a real come***ion look and new ideas keep coming.
    Friends Kids checking it out, They seemed to approve:p
  21. rottenleonard
    rottenleonard
    Next was a grill I had been looking at maby buying some sort of premade perforated aluminum sheet but decided to take a wack at making one instead, The first try need a little mor thinking and less hole punching( I didn't like how it didn't have a patern on two axis's)
    starting again with a little more thought
    all shot full of holes
    with the trim on I still desperatly need the lower trim piece that ties the bottom together.
    before tear down the car would over heat during the hot august nights cruize, a few laps idling with the occasional burn out would send the temps over 220 degrees (why is there no degrees simble on a keyboard?)
    and with the new grill probably being more restrictive than what was on it previosly I fugured a fan shroud was in order.
    paper template
    .060 aluminum bent to a 90
    a little work with the shrinker
    make believe template come real life
    intalled the shell to find the center of the fan
    like the look?
    found center and drilled for the circle cutter(another home made tool)
    presto whamo!
    next I cut a 2.5" strip and formed it inside of the shroud and rivited the ends together(it was a little more than 48" so I actually had to add in some filler strip)
    mounted on the bead roller with the tipping die, I wasn't sure this would work but it sounded a lot easier than the streatcher
    yup....works
    the shroud looked a little plain so in went a few beads to jazz it up.
    ***embled it all and rivited with solid rivets, and gave it a brushed look with some scotch pads
    Then doom and gloom set in I hadn't accounted for the frame rails being tapered in, I can't get the grill far enough forward to get past the fan, and I cant get the bolts in the fan after the grill is installed, sooo...... F$CK!!!!!!
    I think I will rework the bottom of the shroud to be removable... It sounded like a good time to quit before flustration reaked havok.
    all in all I'm happy with where it's going.
    Thanks all
    Robert
  22. lorodz
    lorodz
    wow its coming alng nicley
  23. bct
    bct
    nice work....too bad about the shell but you will figure something out and it will be as cool as the rest of your work!
  24. That shroud looks great! You'll figure it out.
    Tha whole project is coming along nicely. Well done.
  25. THE_DUDE
    THE_DUDE
    Looks rad. Did it have a vibration? the rear pinion angle looks a little wacky. Glad to see the Progress way to go on the metal work on the grill shell
  26. PeeVee
    PeeVee
    I like the new paint. The grill and shroud are turning out top notch.
  27. Kustom Komet
    Kustom Komet
    On my Mac, it's option+0 (number zero at the top of the keyboard, not the number pad to the right) so it looks like this:
    220º
    On a PC, you might try the alt key plus the numbers up top, or alt+0176 on the right keypad.
    -KK
  28. rottenleonard
    rottenleonard
    It does look funky in the pictures, but it is the canceling angle to the joint at the slip yoke.
  29. rottenleonard
    rottenleonard
    Hey Pat,
    Hows the cabriolet coming along you should snap some picts and post the project. did you make a decision on a power plant?
  30. Django
    Django
    from Chicago
    Wow, that is really look great! I'm impressed.
    Well, Technically (puts on art director hat), option+0 yields a Masculine Ordinal Number for Spanish and Italian. Option+8 is the actual degree symbol. º vs ° .
