Technical Good Battery Option.
Discussion in 'The Hokey Ass Message Board' started by Al T, Sep 8, 2018.
  1. I’ve used this battery in my ‘32 and just replaced the car battery in my ‘37 with one as well.
    http://aircraftproducts.wicksaircraft.com/viewitems/aircraft-batteries/odyssey-drycell-battery
    The battery is a great option for your car so thought I’d share.
    It’s a dry cell aircraft battery that I buy through Wicks Aircraft in Illinois.
    I use the 680 ($132). It’s 680 cranking amps with a small profile (6-9/16” x 3-1/16” x 7-3/16”) and weighs probably half the weight of a car battery. Because it’s a dry cell it does not need to be mounted in an upright position. Wicks also sells a battery box to mount the battery (you can see it in the photos) as well as a post mount kit (used on my ‘37). These batteries hold their charge much better than an auto battery.
    I have no affiliation with Wicks....... or any aviation battery manufacturer, but it’s a great option for your car. Not sure if this option is well known, so thought I’d put a post up.
    My ‘32
    My ‘37...... in the same location the auto battery was, taking a 1/4 of the space.
    BigChief and RHRH3P like this.
  2. In the photo of the ‘37, you can see the imprint of the auto battery in the carpet.
  3. 56don
    56don
    I have had one in my 32 for a few years now. Have a spot for one just like it in my 34 truck. They are remarkable if you have just a hot rod and not a luxury liner.
  4. I buy my 12 volt batterys from the local Farm Service Coop. I tellthen I want a power unit battery. and they go to a pallet and get a battery and brand it. That way there is no warranty. cost $40 with a exchange. High cranking amp heavy battery last me about 4 years. I play musical batterys and sometimes use them on tractors that don't charge ect.
    slack likes this.
  5. cajunfirehawk
    cajunfirehawk
    from Gulf Coast
  6. Mike VV
    Mike VV
    from SoCal
    Another interesting choice -
    https://earthxbatteries.com/
    I have had Lithium batteries in my sport bikes for a few years now. Work great. No cold or hot start problems.
    Just don't "overcharge" them.
    Mike
  7. BJR
    BJR
    Will all of the batteries mentioned work OK with a standard car charging system? Alternator or generator, or does the charging system need to be changed?
  8. robracer1
    robracer1
    I've had a PC 925 over two years in my 32 roadster, works great and sure is a space saver.
    56don likes this.
  9. 56don
    56don
    I have had an odyssey PC925 dry cell battery in my avatar for probably 6 years or so. I regularly take it out to run my tractor then put it back. I use it around the house for starting other cars I am working on. All use a regular alternator system. This battery don't care what charging system you have. They will run completely dead and charge right back up, no sweat. You can also keep a trickle charger on them. You can mount it in any direction, no liquid to run out.
    robracer1 likes this.
  10. ct1932ford
    ct1932ford
    Have been running the 680 over six years in my roadster. Love it! Mounted under the seat. 006.JPG
    HunterYJ and 40FORDPU like this.
  11. tfeverfred
    tfeverfred
    Good info here. I'll be using one in my T Bucket. If it ever gets done.:(
  12. IowaMercMan
    IowaMercMan
    Of course I fabbed a spot under the seat for a standard battery. I’m right at the point of actually buying the battery so this post is timely. I can surely use the space some other way! Cool.
  13. X38
    X38
    Been using them for 18 years. Only just put the 3rd one in the roadster in that time. So that's basically 9 years life per battery. Pretty good I think.
  14. nunattax
    nunattax
    GREAT CHOICE ,don't think its traditional though.
  15. Seriously?
    Should I convert my ‘32 and ‘37 back to 6 volt?
    Sporty45, TagMan, upspirate and 2 others like this.
  16. clem
    clem
    So according to their web site, their 680 cranking amps is $379. Quite pricey compared to the Odessey battery. Is this due to being a lithium battery compared to Odessey being different?
  17. 2935ford
    2935ford
    Odyssey........yup, good stuff!
  18. brady1929
    brady1929
    Good info here.
  19. cajunfirehawk
    cajunfirehawk
    from Gulf Coast
    So just to clarify, this little battery is NOT 680 Cold Cranking amps, AFAIK, the "680" is just some part number nomenclature they use, from Odyssey's website the specs on the battery are:
    • Pulse (5-second) Hot Cranking Amps (PHCA) 520
    • Cold Cranking Amps (CCA) 170
    • 20Hr Nominal Capacity (Ah) 16
    • Reserve Capacity Minutes 24
    • Dimensions L x W x H (in) 7.15 x 3.00 x 6.65
    • Metric Dimensions L x W x H (mm) 181.5 x 76.3 x 167.8
    • Weight (lbs) 15.4
    • Weight (kg) 7
    Link to odysseys page on this battery------> pc680
    YMMV
  20. modified
    modified
    I have a PC680 in my Modified that is about 10 years old and still going strong!
    No float charger, A kill switch does the job!
    Sent from my SM-N900V using The H.A.M.B. mobile app
    cajunfirehawk likes this.
  21. Hmmmm........ regsrdless of the cold cranking amps, I’ve had no issues with it.
