Good CHEATING stories?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Feb 15, 2007.
  1. My dad used to drag race back in the late '60's early '70's. I don't know the specifics of what cl*** he was supposed to be in. But anyway...he was running an an all aluminum big block 427 in his firebird which wasn't allowed for his cl*** (only cast iron allowed) but he had it painted chevy orange and never mentioned it. He kept squeezing by tech and kicking *** all the way.
    One night this inspector decided to stick a magnet to the block. "AH HA! I caught you!"
    After a little cussing and name calling dad loads it on the trailer and hauls it home.
    That week he got the idea to pull the motor and spray paint the block again with steel/iron filings in the paint.
    Went back the next week. Same inspector comes over and says, "Wha ya cheating *******....you're back again trying to pull the same sh...(as he sticks the magnet to the block and it stays this time).....uh....huh?"
  2. Ricci32
    Ricci32
    We used a set of chet herbert roller lifters that guide through the oil gallies in a flat tappet cam cl*** even cut a grove in the top of the lifter for the snap ring to look like a hydraulic lifter.
  3. Ricci32
    Ricci32
    Also in a stock flywheel cl*** removed the ring gear drilled the flywheel to lighten and put the ring gear back on.
  4. Ricci32
    Ricci32
    We used to mix our own fuel we would get a additive from a guy in NJ called liquid balls im not kidding everytime it came it was in a different container up around 20 percent it would burn a piston..
  5. Ricci32
    Ricci32
    Its not cheating if you dont get cought!!!!!!!!!!!!!
  6. Ricci32
    Ricci32
    We had a big block 467cid rule i had a custom big bore short stroke motor that burned a crank so we installed a standard crank and had aprox 540 inches
  7. Well I did hook up with this . . . Oh you ment stories about cars. :eek:
    I don't recall who it was but back during the cam wars or whatever the popular name is today one of the fellas running a '33 Willys used the spare tire mounted in place and filled with concrete for a traction advantage.
    The Ol' Man was pitting for a fella running Modified Sports Car way back when and there was a vette that kept winning. The vette didn't sound right. The Ol' man would protest and pay to pull a head but the fella kept pulling the same head. He finally payed enough to pull both heads. One bank was overbored. It must have been a balancers nightmare, but it gave them an edge.
  8. styleline
    styleline
    from so-hol
    nice storys guys
  9. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  10. bearmtnmartin
    bearmtnmartin
    from B.C.
    I found this thread because I was looking for new ways to cheat. My mini stock has a fully adjustable suspension because I ground the weld off the macpherson strut brackets and now I can raise and lower the ride height. On another car we mix and match the top hat over the strut because a lot of them are different heights, so you can play with the weights that way. Pretty much undetectable. Also helps to use a car no one else has because the tech guys have no idea what is stock. They can't know everything. I found this thread looking for a way to change the size label on a drive tire so I can add stagger. Rules say 4 same size tires, but I will figure it out. I'm open to suggestions....
  11. CoolHand
    CoolHand
    Alliance Vendor
    You can change the OD of the tire by running them on a different width rim.
    Say they're meant to run on a 6" wheel, so you run the insides on 7" wheels and the outsides of 5" wheels.
    The wider wheel will make the inside tire run with a slightly smaller OD, and the narrower wheel will make the outside tire run with a slightly larger OD.
    We used to switch from an 8" to a 7" wide wheel on the RR of our modified when we needed more stagger than the tires would give us.
    Also, look for bias ply tires that you can shave the tread on, then take and inflate the holy hell out of the outsides and let them set for a day or two like that.
    They'll stretch a little bit, and stay bigger around even when you reduce the pressure to race on them.
    The race tires we ran would stretch upwards of an inch in cir***ference if you left them at 40 psi for the entire week before the race. They didn't seem to go back down in size much afterwards either, but street tires might.
    If they do shrink back to their original size, it'll take some time. You ought to be able to get at least one night's racing out of them before they shrink much to speak of.
    Another nice side benefit of bias ply tires is that they can be found in much softer tread compounds than your standard p***enger radial. 10k mile bias tires will be much softer than 60k mile radials.
    Just something to ponder on.
    kbgreen likes this.
  12. Rumbler
    Rumbler
    This is the first thread on hamb that I have read from beginning to end, and I am completely floored at all of the great stories and innovative tricks that have been created all in the name of speed. Keep it up guys i'm takn' notes!!!
  13. torino_Joe
    torino_Joe
    Why does that not suprise me that your on here,probably looking for more stories like the time we went racing in "new mexico" and Shaun set you out a bit and helped you on the go:eek:!!!! Nailed that launch too:cool:
  14. norton58
    norton58
    A local drag racer here in Victoria used to run flat 9s at Calder, all day, every day. Never broke out, never blew up, flat 9s each time. It turned out he was in the RAAF (Royal Australian Air Force) and flew a BlackHawk chopper over the dragstrip and digitally mapped the surface of the track. Transferred that info into the computer in the car, thus it knew when to back off for bumps, go hard on the flat bits, etc. *****!
    kbgreen likes this.
  15. Jimm56
    Jimm56
    Best thread ever!
    Once upon a time we had a street racer with two 58? (I think) Corvettes. Identical mild customs, they were, except for the engines. One, a 283 and the other sporting a hot 409. He's set up a race to start just past his house, swap cars and whup your a** then swap back to collect his money. Hoods were never opened. Reportely he owns the cars to this day, never have they both been seen together.
  16. Any more stories? I just read this entire thread! Great stuff.. Im surprised no one has mentioned Fred Lorenzen's Yellow Banana yet.
  17. Things are a little clearer in this pic...
  18. damagedduck
    damagedduck
    from Greeley Co
    most of my 'racing' stories are from the back streets:eek:.
    a Dodge Polara with a huge small block{Chrysler} in it with big block wagon spring in front & air shocks that holes drilled in em,that thing would left the front & slam the rear as the weight would transfer,made plenty of chevy guys cry when we open the hood & see a dirty old 318 :D never looked twice at the water filled spare tire..:D
  19. wagoon78
    wagoon78
    Not drag or nascar, but sometimes you gotta start them early. My younger cousin raced quarter midgets and I used to help out my uncle every now and then. He would always watch the race with a couple of heavy wrenches in his hand "just in case something broke". While pushing the car across the scales, somehow the heavy wrenches made it into the car. I guess he had to put them somewhere to help push.
  20. gibraltar72
    gibraltar72
    from Osseo Mi.
  21. Sir Woosh
    Sir Woosh
    Guess I'm a scoundrel. I've always enjoyed a good cheat. I've learned a lot from it both mine and others................
  22. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Growing up, I was always told that cheaters never win!!.......But found out later that cheaters always win....
  23. fossilfish
    fossilfish
    from Texas
    Garlits staggered the front wheels on his rails to cut lower ET's. Did it for a long time before folks figured it out.
    Smokey placed a basket ball in his BIG fuel cell with a little connecter underneath p***ed fuel volume test with ball inflated then after, let the air out. Time for another check slip under car with a small bottle of compressed air in a second legal tank again.
  24. alv
    alv
    from jackson,NJ
    we had a guy at our circle track in nj that put the magnets and pickup from an old cruise control on his driveshaft and drove people nuts. he had many cheating parts on the car but everyone looked at this instead and scratched their heads. i was not even hooked to anything just put there to throw the lookers off track.
  25. Trichop
    Trichop
    from Eaton,Ohio
    Back in the 60's ,my friend, Dave Reid, ran a D/Gas 57 Chevy convert named "Motivation"
    He ran a "Moon" tank off the front like most of the g***ers of the day
    We were at Pence's Dragstrip (Ohio) when he got caught draining water out of his "Stock" 57 Chevy gas tank '
    OOps...
    Seems he should have ran C/ Gas'
    the extra weight put him down a cl***
    He was banned for the whole season
    I was running N/Stock with a 1965 Merc Comet Convert
    I slipped a Hipo 271 HP motor in the car
    I ran a 2 barrel intake (with stock air cleaner)
    as soon as I went thru inspection, I would swap the carb for a modified 600 cfm Holly
    I ran 3 different tracks...never got caught
    OLE442 likes this.
  26. oj
    oj
    Theres more than a few stories here about nitrous and prostock racing, right thru the gliddens and jerry echman(?) - problem with all of that is nitrous was not 'illegal' in prostock racing at that time! It was a general agreement a****st nhra and the prostock teams not to run nitrous. It was after echmans' incident that a rule went into the book. I have rule books going back many years. There might be a rule about prop, i know that prop was a favorite of bob glidden and he admitted to experementing with it.
    Back in the early days of msd we used to watch a compe***or make a p*** and we'd have a friend parked midway in a truck and we'd hail him on the c.b. that everybody used to talk back and forth with. He'd answer and trigger is 'side band' (thats what it was called, is was like an amplifier) just when the compe***or was closest to him and it would kill the msd ignition! I swear to christ! You could hear that box popping and banging all the way back to the starting line. It took msd a while but they finally got around to shielding the box, i know of more than a few of those old boxes went into the trash because of that. But then you didn't hear this from me ok?
    kbgreen likes this.
  27. barryvanhook
    barryvanhook
    from Mesa, AZ
    Back in Peoria, IL, and long before the Peoria strip was named Boondocks Drag Strip, a friend of mine ran his '56 Chevy with 283 4v in a low gas cl***. He had a spare tire that was filled with gravel, which was just enough to allow him to make his weight into a lower gas cl*** where he was highly compe***ive, at least so long as he left his spare in the pits. As far as I know, he never got caught.
  28. rjaustin421
    rjaustin421
    In the late 1970's Richard Mash from the Taylorsville NC area had a Nascar Darlington Dash Vega with Dean Combs driving that ran roughshod over everyone for quite a few years in a row.
    The inspectors wanted to curb the costs so they outlawed the multiple disc clutches which were real small diameter.. Next race out Dean stomped everyone yet again & the inspectors made him drop the ******. As soon as they saw the small clutch cover Rich was told to load up...he was illegal.
    Rich told them to look closer, there was only 1 disc installed not multiple discs. As Rich told it the head inspector said something to the effect of "Boys, you got us again"
  29. Carnuba
    Carnuba
    COOL! We don't need no stinking templates
  30. jetnow1
    jetnow1
    from CT
    Way before Petty and Smokey there was a Flathead Ford racer who had used Ford tractor valves in his engine- they looked stock as they had the cast ford logo but were
    1/8 inch larger. Wish I could remember more of the details...Jim
    kbgreen likes this.
