Technical Good Engine Builders in LA / Ventura area?
Discussion in 'The Hokey Ass Message Board' started by deto, Mar 5, 2015.
  1. deto
    deto
    As the ***le states...
    I'm looing for a good engine builder in the LA / Ventura county area.
    I have a fresh 327 short block and heads, but I would like to have it ***embled and dyno'd by someone who knows what they're doing.
    I have also looked at crate motors, but I would like to help keep a local guy in business, and I like the way the 327 looks versus the new crate motors.
    Any help would be appreciated. Thanks.
  2. dreracecar
    dreracecar
    from so-cal
    money is no object then
  3. jimcolwell
    jimcolwell
    from Amarillo
    Keep in mind if one of those "know it all" makes an error you'll need to tear it down again. The difference in torque will make you a believer in 350 crate engines. Swap all the outside parts off that 327 and buy a balancer and got the best of all worlds.
  4. burbank speed and machine , guys name is dave.... very honest good builder
    818 470 6398 located in burbank ca right off the 5 fwy
  5. deto
    deto
    Expound please...
  6. deto
    deto
    Great thanks
  7. toml24
    toml24
    You might try Speedway Transmission in Ontario. The business is owned and operated by Mike Johnson, who races Late Model oval stocks at Irwindale Speedway on Saturday nights. Mike is very cool and if he can't help might be able to send you in the correct direction. Here is the contact info and the man himself. Good luck.
  8. dreracecar
    dreracecar
    from so-cal
    Because what you asked for varies in degrees and expence. A "good" or "knowlagable" does not take anything for granted towards a engine build and that equals billable hours or a high fixed price to cover any issues that may arise during the build. Dyno time can be around $450/$500 for a half day, and most of that time is used just setting everything up and maybe 2 pulls and 1 jet and timing change.Hope you get in contact with some of the individuals mentioned and can get you going without major h***les or expence
  9. Pewsplace
    Pewsplace
    Ron Dunlap of R&D machine did my 327 and it runs great. I built it as I like the engine era 327/350 hp - 65 Corvette. Ron is good and reasonable. If you want a race shop to build your motor then the price will be double or more. RPM in the same area builds lots of race motors and have a dyno. The last one my friend cost around $10,000.
    Both of these shops are in Chatsworth.
  10. deto
    deto
    Pew are you in simi?
  11. Pewsplace
    Pewsplace
    Yes!
  12. deto
    deto
    I'm in moorpark. If you ever need anything or need another hand with something give me a shout.
  13. deto
    deto
    See above
  14. Pewsplace
    Pewsplace
    Nice to meet you. I am starting another roadster project and will need some of your services I'm sure.
    Lynn
  15. 1gearhead
    1gearhead
    I have been using JMS Racing for the last few years and would highly recommend them. They are honest, competent and seasonably priced. They are located at 5450 N. Peck Road In El Monte. (626) 579-4567 Mike is a good guy to work with.
  16. deto
    deto
    Sounds good. Just let me know...
  17. deto
    deto
    OK I will check him out
  18. Greg hit up Danny at Sharps Automotive in oxnard
