History GOOD GOOGLY MOOGLY, WHAT WAS THIS GUY THINKING?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Sep 6, 2023.
  1. Dave G in Gansevoort
    from Upstate NY
    Now envision this: instead of hauling the boat with the trailer, just build the lower portion as a boat. Drive to the lake, drive in, engage water propulsion system, and Bob's your uncle...
    millersgarage and HOTRODPRIMER like this.
  2. j hansen
    j hansen
    A bigger picture..
  3. I am not sure that suspension mod would “float” with the crowd around here.
    lostone, Deuces and HOTRODPRIMER like this.
  4. Oneball
    Oneball
    There’s a hotel over here that’s separated from the mainland by the tides. Theyve had something similar to get across since the 1920s
    And the current one.
  5. goldmountain
    goldmountain
    A dropped axle could fix that.
    HOTRODPRIMER likes this.
  6. Mark Grabo
    Mark Grabo
    from Upstate NY
    Does that thing have two front axles that a chis crossed ?
  7. It looks to have a scissor effect in action. 2 planks of metal attached to the spring, crossed to the opposite perch?, with a bolt through the center "X". I think it also looks to have some bar connecting the front and rear axles?.
  8. LOST ANGEL
    LOST ANGEL
  9. 3W JOHN
    3W JOHN
    Looks like a early swamp buggy.
  10. 210superair
    210superair
    from Michigan
    Just early donks, all these pics.... Lol
  11. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Giving the fab guys some props. Not necessarily the conceptual guys though. Yikes.
    Sheck out that wheel building ingenuity!
    The fronts of the A sedan are A spoke wheels affixed to tractor hoops.
    the fronts on the modded Forty Ford sedan (a crime I tell ya) are a fairly crafty truck wheel adapted with large flat steel spokes to the tractor hoops. When I worked in a bike shop I built a ton of spoked wheels. It aint brain surgery but it's an exacting process.
  12. Can't remember if Model Ts had cross steer or a push-pull drag link to the left spindle, but in either case I'm not sure how he worked the steering linkage on that thing.
  13. GordonC
    GordonC
    Originator of the Carolina Squat!:D
    rattlecanrods and HOTRODPRIMER like this.
  14. 1952henry
    1952henry
    The dualed-up 1.5 ton Fors was actually an offering from Marmon Herrington. MH converted Fords to 4wd as a factory-authorized accessory.
    LOST ANGEL and HOTRODPRIMER like this.
  15. Los_Control
    Los_Control
    from TX
    Just incredible how people did what they needed to do back then ... you can see in the back ground there was a horse & wagon and another truck going through the same situation.
    This guy clearly had it under control using his brains and labor.
    down-the-road and HOTRODPRIMER like this.
  16. Rickybop
    Rickybop
    "Have you ever wondered how the man who drives the rescue boat... gets to the rescue boat?"
    '28phonebooth and HOTRODPRIMER like this.
  17. 49ratfink
    49ratfink
    anyone know of a Hot Rod done with that body? I don't think I've ever seen a 4 door
  18. HOTRODPRIMER
    HOTRODPRIMER
    Remember the old television commercial about how the snowplow driver gets to work? HRP
    Off topic
  19. Rickybop
    Rickybop
    Exactly, Danny.
    Thought you might remember.
  20. Deuces
    Deuces
    Texas who???...:rolleyes:
  21. BJR
    BJR
    How does the car in the original picture steer? I don't see anything that looks like it would turn the front wheels.
    HOTRODPRIMER and 46international like this.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Maybe it's like the old cogwheel wagons like when we were kid's, they use ropes tied to each hub,, pull the left wheel rope and go left, pull the right rope and you turn right. HRP
    BJR likes this.
  23. Dave G in Gansevoort
    from Upstate NY
    And a tall step ladder!
    HOTRODPRIMER and rattlecanrods like this.
  24. -Brent-
    -Brent-
    Florida man, 1920s edition.
    HOTRODPRIMER and Mainedrifter2 like this.
  25. 2935ford
    2935ford
    nice pinion angle! :(
  26. curbspeed
    curbspeed
    But easy to get to
    HOTRODPRIMER and LOST ANGEL like this.
  27. lostone
    lostone
    from kansas
    "That ain't traditional !! " hahaha !!
  28. 26 T Ford RPU
    26 T Ford RPU
    Driver had a bad back and couldn't bend to crank it. JW
  29. Or stop? I don't see any brake rods.
