Technical Good recommendation for a chassis book
Discussion in 'The Hokey Ass Message Board' started by PhoenixFear, Jan 1, 2021.
  1. PhoenixFear
    PhoenixFear
    Apologies in advance if this isn’t a traditional topic but I’m looking for books to perhaps help me dive into what’s involved in building a Model A ch***is. I’m a beginner at best so a cookie cutter approach would be easiest to handle. A few years ago I tried building a ‘33 Ford I inherited without any real clue what I was doing and of course made a bunch of mistakes; I’d like to do some research before taking on another project. Thanks.
    rbrewer likes this.
  2. Do you want stock or HAMB friendly? Or something in between? Any plans on what engine you are going to use?
    Charlie Stephens
  3. PhoenixFear
    PhoenixFear
    Not stock but I’m afraid not exactly H.A.M.B. friendly. Basic SBC/TH350 or 700R4, 9” rear, Mustang II front maybe? Not sure what to use. I discovered Boling Bros. ch***is and am seriously considering building one but there are so many options.
  4. Get Vern tardel’s book.
    Model A ch***is is very simple if you can fabricate. If you can’t fabricate then any ch***is isn’t the thing to start with.
    Them M2 “kits” are taboo here but none the less something to study. Once you understand how a front suspension is supposed to work you’ll discover why the kits are really a poor choice.
    Baumi likes this.
  5. Budget36
    Budget36
    Look up Billy Shoop on the internet, I recall reading some of his stuff many years ago...***uming you are going OT from the HAMB
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    31 Vic is correct. Other decent books are the hotrod series done by Tex Smith. Not "blueprint" type, but good info. M2 kits would be ok (not here) but "engineering" geometry ****s & isn't worth attempting to repair. IMO, 'bout the only reason they're accepted is due to the pimping by Street-rodder, a**** others, (read cubic advertising $$$) from the mfrgs, instead of telling/showing/constructing w/correct geometry. That & most folks don't care to know how n why stuff really works. Some custom ifs are very good, but stupid money.
    Marcus...
  7. krylon32
    krylon32
    from Nebraska
    My advise is to stick with a straight axle front and rear. The straight axle ch***is is much easier for a novice builder. Do lots research before starting and do lots of measuring while building and you will be fine. Order a P&J catalog and study the picture of the Model A ch***is they have and study their offerings of ch***is components. There's also nothing wrong with using original Ford parts either. Just take your time.
    31Apickup and seadog like this.
  8. X38
    X38
    This.
    The P&J website also has tech pages on suspensions with diagrams of how things work. Should be mandatory study.
    seadog likes this.
  9. PhoenixFear
    PhoenixFear
    If the straight axle rides fine I’d go that route. I have an old How To Build Hot Rods book from the ‘50s I forgot I had but I figure there is much better info now.
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    The how to build hot rods series from Tex, was done circa 90's, iirc. Different books covered different makes, engines, types. Anyways, good books for info, n ideas. Best bet is HalfPricedBook stores, ebay, amazon.
    Marcus...
  11. krylon32
    krylon32
    from Nebraska
    Over the last 40+ years of ch***is building for customers less than 10% of the ch***is have had independent front ends. I've done a lot of straight axle ch***is and a buggy spring both front and rear will ride fine if the right components are used and they are installed correctly. I never had an instruction manual I just studied how everybody was doing theirs and applied that knowledge to my first scratch built ch***is in 1970, It was a 32 with a Chevy II 4 banger and power glide with an early Ford banjo rear. I had no idea what I was doing but it turned out good and worked under the Speedway 32 roadster body I built.
    warbird1 and dadz34 like this.
  12. lostone
    lostone
    from kansas
