Hot Rods Good source for hiem joints and ladder bar questions
Discussion in 'The Hokey Ass Message Board' started by Gus68, Jun 24, 2025.
  1. Gus68
    Gus68
    from Minnesota
    Soooo.... I'm planning on building ladder bars for my 57 chevy gasser project. I'm going to build them outta square tubing, so I'm going to need some square threaded weld in bungs for my hiem joints. I'm planning on using 3/4 inch hiem joints, so 3/4 inch thread. The other thing is what size square tubing to use that would be best for ladder bars that would also work with the weld in bungs that are available? And also, who would be the best one stop shop, to order joints and bungs and adjusters, that are also good quality?? I just go crazy trying to piece together stuff from one place and another. Any advice would be wonderful!!!
    chevy57dude likes this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Probably easier & far less time consuming to order bars & accessories already done ( might even be cheaper )
  3. chevy57dude
    chevy57dude
    Get ready for the sky is falling crowd.
    S&W Race cars in Spring City PA can handle all the ends. There's probably someone closer to you, though.
    Also, they sell a 42'' gasser ladder bar with chromoly rod ends.
    51 mercules, bobss396 and jaw22w like this.
  4. partsdawg
    partsdawg
    from Minnesota
    Check Racing Junk and dig around locally. Someone may have a set locally that were removed 50 years ago.
  5. pirate
    pirate
    from Alabama
    Midwest Control Products Corporation https://midwestcontrol.com/shop/ I have purchased numerous items from them. In addition the catalog gives a lot of information about hiem joint types, construction, material and sizes. Plus they sell clevis, cables and other useful stuff for the hot rodder.
  6. Gus68
    Gus68
    from Minnesota
    Thanks pirate!!! Ive never heard of that place, but looks good, prices are fair. I have an idea of what I want my ladder bars to look like, and also need them to be a certain length. So buying a pre-made set ain't gonna cut it.
  7. Gus68
    Gus68
    from Minnesota
    So what would be a good size square
    tubing for ladder bars?
  8. DDDenny
    If you are set on square tubing and plan on doing any serious racing I would find the heaviest wall two inch tubing available, such as 3/16" or 1/4" wall.
    You will need to custom make your threaded inserts based on the chosen tubing, about one inch thick, just relieve the weld seam and make sure to get good weld penetration, it also wouldn't hurt to plug weld them also.
    bobss396 likes this.
  9. DDDenny
    Just realized you are building ladder bars, so two inch would look a bit odd but this 11/2"×.188 wall tubing would work with correctly located diagonal bracing.
    https://www.speedymetals.com/pc-4772-8251-1-12-x-1203264-x-1-12-wall-square-steel-tubing.aspx
  10. Gus68
    Gus68
    from Minnesota
    Ya, 2 inch might look a little chunky. Do you think someone makes square bungs in 1.124?
  11. DDDenny
    I'm 99% sure nothing like that is available, need to find someone to drill and tap 3/4-16 (NF) in round stock and part off two pieces 1 inch long, grind four flats on each to fit tube, the extra weld in the corners will be a benefit anyway.
  12. Gus68
    Gus68
    from Minnesota
    I MIGHT know someone. I'm not sure. I will do some checking
  13. manyolcars
    manyolcars
    You may find the parts you want at an OffRoader supply.
  14. There used to be a place called Rod End Supply. I bought stuff from them some years ago. I built some upper rear links for a '62 Pontiac project (like to know where that car went). I used 2x2x1/8 box tubing, I cut a piece of 3/4x2 flat bar to fit the tubing like a cap. drilled and tapped 3/4 thread for the rod end. Gene.
  15. chopolds
    chopolds
    from howell, nj
    Thor Bros. sells 2" square tubing, with threaded bungs, and different ends for them.
  16. 1971BB427
    1971BB427
    from Oregon
    I've used QS Components for a couple decades now for all of my various builds. Great prices, and fast delivery. I build all of my own ladder bars, tie rods, panhard bars, etc. and they have all the ends, brackets, weld bungs, etc.
  17. Gus68
    Gus68
    from Minnesota
    1971bb427, have you built square tube ladder bars before??? Any tips on building?
  18. pprather
    pprather
  19. 1971BB427
    1971BB427
    from Oregon
    Built as many square tube as I have round tube. I use the same weld bungs for square tube and just add weld at the open square corners on the weld bungs. Square is even easier to weld at all the various joints since it's just cutting the angles to match well.
    One thing I think all ladder bars need is inline adjusters at the bottom tube in the rear! Without them it's a nightmare to adjust pinion angles. And also make the two tubes that attach to the axle bracket parallel to each other or you'll fight getting them bolted or unbolted once they're adjusted.
    Fordors likes this.
