This may sound fundamental, but for those of us budding Holley gurus, Mike Urich's "Holley 4150 & 4160 Carburetor Handbook" is an easy and very interesting read. Most interesting are the very slight differences between the center-hung float 4160 and the emissions or RV 4160 (of which I'm rebuilding) and o' course the minor differences between the 4150 & 4160, all explained in-depth but easy to follow. What are some Tech reads you recommend?
Carter Carburetors by Dave Emanuel. From S-A publishing. some interesting history at the front, good basics next, some model specific stuff and some rebuild breakdowns. I have the Holley book mentioned and agree that it's a good one. One of the best books in my library is Smokey Yunicks "Power Secrets." Written around the SBC, but theres a lot of good info that applies to any engine. Keep an eye out for a small, but thick book - printed on bible paper, titled: Machinery's Handbook 22. (Or 21 or 18 etc.) They are expensive when purchased new, around $42. or better now, but if you spot one at a garage sale, grab it. It has so much metal oriented stuff in it that you'll find it hard to believe. A small example - bluing metal, several methods, as well as making it brown, plum or purple colored. Not to mention multi-colored for some metals. No paint involved....
Thanks Rocknrod, I have a brand new Speed Demon I had just about given up on, just about ruined newly built engine dumping gas. Demon tech line is useless. Good & timely info. Thanks!!
[ QUOTE ] Keep an eye out for a small, but thick book - printed on bible paper, titled: Machinery's Handbook 22. (Or 21 or 18 etc.) They are expensive when purchased new, around $42. or better now, but if you spot one at a garage sale, grab it. It has so much metal oriented stuff in it that you'll find it hard to believe. A small example - bluing metal, several methods, as well as making it brown, plum or purple colored. Not to mention multi-colored for some metals. [/ QUOTE ] It must have been a long time ago that you bought one of these! They're up around $75 for the bible-sized one and a bit more for the phone book-sized one, even more if you want the CD too. Worth every penny though. I don't have a personal copy, but I use one at work at least 2-3 times a week. This morning I used it to size a keyway. Ed PS- As far as good tech books go, buy anything from David Vizard. I'm chewing through "How to Build Max Perf SBCs on a Budget" right now. HOLY CHIT. You'd think the guy was a HAMBer with how dirty and low-buck most of his techniques are.
