Hot Rods Good way to remove paint from stainless steel?
Discussion in 'The Hokey Ass Message Board' started by banjorear, Sep 30, 2009.
  1. banjorear
    banjorear
    OK, I found an original '32 headlight bar cheap (not perfect but perfect for what I want to do) that I would like to cut up and make in to a low mounted piece for the front of my roadster.
    Someone painted over the stainless center piece. I'm ***uming it would be OK to use thinner or some type of paint remover without messing up the stainless underneath.
    Is this a correct ***umption? Thanks.
    Banjo
  2. Stu D Baker
    Stu D Baker
    from Illinois
    you sir, are correct.
  3. inliner54
    inliner54
    steel wool works good too
  4. chaotic
    chaotic
    Paint stripper will work good.
  5. stealthcruiser
    stealthcruiser
    Heat, as in an oven, about 400 degrees.
    No torches, please.
    A heavy duty heat gun, on the other hand....................
  6. Saxon
    Saxon
    from MN
    2x Steel wool
  7. InPrimer
    InPrimer
    Oven cleaner at the $1.00 store. wear gloves
  8. stuart in mn
    stuart in mn
    Just use some regular old paint stripper. It won't harm the stainless.
  9. If you use the oven cleaner make sure you get one with caustic in it or it wont do a thing. All good ideas posted above, about the only way you will screw up stainless is with a flame.
    I would go paint stripper then steel wool, get some course and some fine for finishing.
    Doc.
