Technical GOT A BITCH
Discussion in 'The Hokey Ass Message Board' started by frosty-49, May 1, 2016.
  1. slack
    slack
    Sometimes you gotta go OT to make a point. The imports have their **** in one sock on "technician consideration." It's our own domestics that have no consideration for the DIYer. Now why do you suppose that is?:rolleyes:
  2. Bandit Billy
    Bandit Billy
    My name is Bill and I once bought a new Mercedes. That was in 2003 and I have been clean for a decade now.
    I mention it only because the "tri star"garage doesn't drain motor oil or radiators they extract the fluids. No leaks, no drips, no mess, environmentally safe and pretty quick.
    May not be a practical tool for every garage but it beats making a mess.
  3. nmpontiac
    nmpontiac
    from Taos, NM
    On my altered, I put surplus aircraft (fuel) shutoff valves out on the frame rails and plumbed them to fittings in the block with AN lines. You could do the same to your hot rod - they lock open and closed.
  4. Blue One
    Blue One
    from Alberta
    Hey there that's no way to talk about your wife :D:D
  5. pitman
    pitman
    These Photo Dark Room Trays work great. Get the largest one you can find.
  6. ct1932ford
    ct1932ford
    You always know what is about to happen but you do it anyway instead of prepping like you should!:oops: Must be a guy thing:rolleyes:
    tfeverfred likes this.
  7. Mark in Japan
    Mark in Japan
    The HAMBs been going downhill since Buddy Holly died......
    tfeverfred and 117harv like this.
  8. bchctybob
    bchctybob
    Buddy Holly is dead??? I just heard him on the radio yesterday!
    hotrodA and mike bowling like this.
  9. Ron Brown
    Ron Brown
    Had a 79 TransAm with the 6.6 liter 403 Olds motor. Had to remove motor mounts and jack motor up to replace p***enger side rear spark plug....only did it once. after that I drilled a hole on the inner fender panel that I could fit a plug socket thru and removed it that way. HAH, them engineers can only fool me for a so long!!!
    slack likes this.
  10. wsdad
    wsdad
    This gave me an idea. What if you used a wet-vac?
    Sounds messy? Maybe not.
    To catch the oil, you could put a coffee can or a pail or an empty 5 quart oil jug in the bottom of the vacuum's holding tank.
    Then run a small plastic hose from the bottom of the coffee can, up through the vacuum's hose and down the engine's dipstick. I'll bet 1/4" ice maker tube would work. You can get them cheap at Home Depot or off the back of your garage frig.
    Close your hand over the end of the vacuum's hose to regulate it.
    I haven't tried this yet. Just thinking out loud because of Bandit Billy's post. Maybe I'll try this and throw it up on the homemade tools thread if it doesn't **** too bad.
  11. donno21
    donno21
  12. donno21
    donno21
    If you think car's are a *****, try working on Aircraft.
    stimpy and H380 like this.
  13. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Took a spare pet**** to Home depot. Found a small plastic tube that with a little help fits inside the pet****. I insert it in the pet**** and then place the other end in the pan. It drains a bit slower but it all goes in the pan!!!!
  14. captaintaytay
    captaintaytay
    I just go over to my big brothers house and use his driveway for fluid changes.:D
    Bandit Billy and Ron Brown like this.
  15. stimpy
    stimpy
    so are tugboats , USCG was always checking things and your paperwork , and if you had oil in the bilge you had some explaining to do .. on the boats we had a little more room on some things to work on , my buddy told me about replacing fuel bladders on planes , no thanks ...
  16. Bandit Billy
    Bandit Billy
    Pontiacs are supposed to have poncho motors. First sentence was all I needed to hear :) Love Olds motors...in 442's...and jet boats (yes, I had a mullet once too, it was required to pull a day-cruiser with a ranchero in the 80s).
  17. Black Clover Custom
    Black Clover Custom
    Its not my fault if the earth or the people in it cant handle my spills! And its not just radiator fluid and oil either...
    Plenty of other planets somewhere to live on I hear... Lol.
  18. Engine man
    Engine man
    from Wisconsin
    Get one of these from harbor freight to **** the oil or antifreeze. For $150 it can save a lot of headaches. I have one for oil and one for antifreeze.
  19. ironrodder
    ironrodder
    Built a oil ****er use'n a freon tank and a hand full of br*** fittings from Lowes. Just remember to run the dipstick tube hose inside the fitting in the top of the tank. Not a quick process. Plenty of time for a few beers.
  20. hotroddon
    hotroddon
    You obviously have never had to change the trans filter in a Honda Accord - You have to remove the transmission and completely dis***emble the trans - to change the Filter!
  21. tfeverfred
    tfeverfred
    Kinda like the definition of "insanity", isn't it?
    ct1932ford likes this.
  22. tfeverfred
    tfeverfred
    This thread ranks up there with the one about washing "barn finds". Just cl***ic HAMB.:rolleyes:
  23. slack
    slack
    Trans filter, I can live with. It's when I have to raise "the beast" (OT 96 Tahoe) high on all four corners, disconnect fuel lines, drain the tank, and remove the tank all the while having to lay supine (no lift) and ***** around blindly for the fuel lines on top, re-***emble. VS. Remove seat, remove access plate, re-***emble. To do something as simple as changing a fuel pump BECAUSE the manufacturer decided not to put a simple access panel in the floor pan.:rolleyes: And we all know why they do it.:cool: $$$ (Same's your ****** filter)
  24. jazz1
    jazz1
    I put a drain valve in pan of my 700R4 expecting to remove pan occasionally,,,have yet to use drain
  25. mike bowling
    mike bowling
    Ah yup.
  26. wsdad
    wsdad
    Had a chance to try the, "small tube running through a wet-vac hose, into a coffee can sitting inside" thing. It worked really well on antifreeze. I suspect oil would also work well.
    A piece of stiff wire wrapped around the small tube helped keep it from pulling out.
    Once I completed the repair, the antifreeze was still clean because it hadn't touched the dusty vacuum innards. It was easily poured back into the car. And, I didn't have to wipe out the wet-vac before or after the job.
    Edit:
    A few posts back, someone said they had bought two Harbor Freight fluid ****ers for $150 each. One for oil and one for antifreeze. That's a good idea for a pro but I'm a cheep hobbyist and don't want to let go of $300. But it got me to thinking about the, "Bucket Head" vacuum at Home Depot for $22 plus bucket. 5 gallon paint buckets are cheep or free. You could dedicate one bucket for oil, one for antifreeze an one for regular vacuum use. Just swap the vacuum head between them. Then you'd never have to wipe them out or clean them, especially if you had lids. That would simplify things by eliminating the need for the coffee can inside.
    Edit:
    Here's a link to a picture of a Bucket Head vacuum, for anyone who doesn't know what one is.
    wraymen likes this.
  27. hotrodA
    hotrodA
    It all began when the first automotive engineer found his wife in bed with the first automotive mechanic. Before the shooting, he was heard to exclaim "I'll fix you, you SOB"!
    We've been paying for that ever since.
    wraymen likes this.
