Projects Got a little something to put the rocket in.
Discussion in 'The Hokey Ass Message Board' started by J_J2, Feb 24, 2020.
  1. J_J2
    J_J2
    Update on engine, best of three heads is being repaired. Motor is a ‘55 324 that’s been bored to 371 at some point in its life and is now at .030 over. Valve train appears to be stock except for adjustable pushrods. With the heads now being 371 #16 from the #8 that came on the engine when I got it, I’m considering a cam upgrade from stock to take advantage of the better airflow.
    triumph 1, loudbang and Thor1 like this.
  2. J_J2
    J_J2
    Sending the engine out for balancing, now I need a flywheel, which seems to be another issue, does anyone have any suggestions? I’m going to call Wilcap and see if they may have one.
  3. J_J2
    J_J2
    Went through my Olds contacts, going to be picking up a flywheel and pressure plate next weekend! [emoji120]
    loudbang, warbird1 and Paul like this.
  4. bchctybob
    bchctybob
    Wow, so it's a 324 punched out to 4" and .030' more? It's gotta be getting close to maxed out. I bored my 324 to 4" and figured that was it. Didn't know they could go so far.
    loudbang and J_J2 like this.
  5. J_J2
    J_J2
    I was thinking the same thing, but the machinist said there’s still a good amount of cyl. wall left.
    loudbang and bchctybob like this.
  6. J_J2
    J_J2
    Picked up flywheel and pressure plate, and dropped them off at machine shop, for resurfacing, balancing, and rebuild. Heads are repaired and ready for re***embly, progress is finally being made!
  7. vtwhead
    vtwhead
    Good for you J2. Progress looks promising.
    loudbang, Thor1 and J_J2 like this.
  8. Bullet Bird
    Bullet Bird
    Really excited to keep following your build, and you're heart's in the right place with doing a memory build for your old man!
  9. J_J2
    J_J2
    Thank you, I appreciate the kind words. I’m hoping this would make him proud. I was talking to my uncle (dad’s brother) and he’s pretty excited about it, as he drove my dad’s ‘49 quite a bit. He’s been really good about info on dad’s car.
    B Bay Barn, loudbang and Thor1 like this.
  10. J_J2
    J_J2
    Thank you! I’m starting to feel like I’m getting somewhere finally.
  11. vtwhead
    vtwhead
    [​IMG]Are you ***embling the block? Guess this plug should be in the block between the two front cylinders. Don't recall if mine ended up with it or not. This is the pic of @triumph 1 's engine fresh from the shop.
    Apparently installed at the factory according to the ***embly video I have seen from GM. Very curious why this was done, no official answer yet.
  12. J_J2
    J_J2
    The shop will be ***embling the block. Mine has the plugs as well, when I dis***embled the engine I thought it was a blocked p***age at first lol
    chryslerfan55, Thor1 and loudbang like this.
  13. J_J2
    J_J2
    Larry Fulton at Hot Rod Carbs has NOS Rochester small base air horns for 2G carbs, got 3 of them with a choke cover for a J2 setup, along with the 90 degree fuel inlet fittings. Really great guy and very helpful.
  14. vtwhead
    vtwhead
    Larry is a good man. Been at it for a long time. He had bailed me out several times when I was building tri power 348's 10 years ago.
  15. BJR
    BJR
    Everyone gotta love those Rocket motors. Why else would they put Olds valve covers on SBC engines:eek: if they didn't?:D
  16. J_J2
    J_J2
    Will be picking up the engine this week, started prepping its new home.
  17. vtwhead
    vtwhead
    Exciting time, bet you can hardly wait to see the Olds come back. How much did they bore it out?
    Thor1, J_J2 and loudbang like this.
  18. J_J2
    J_J2
    It’s now .030 over 4” bore
    chryslerfan55, loudbang and Thor1 like this.
  19. J_J2
    J_J2
    Well work on the car is going to be postponed for approximately 12 weeks was going to pick up the rear end this weekend and now this
  20. Thor1
    Thor1
    Sooooo, Jared...what's the story there? I don't think you are supposed to have those big gashes in you fingers and palm:eek:o_O:confused:...care to elaborate?
  21. J_J2
    J_J2
    Short story is stepped on brace and sealing it gave grab the first thing in front of me which happened to be a sheet metal duct strap got cuts and severed the flexor tendon in my ring finger. The good news is my cousin’s going to pick up the rear end and my engine this weekend and do what it takes to try to get both put in.!
  22. J_J2
    J_J2
  23. Nova Thug
    Nova Thug
    from SG Vizzle
    Ouch..!
  24. So sorry to see that. It happens to the best of us. Hopefully you will heal up quickly. Take care!
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
  25. vtwhead
    vtwhead
    Jared, that is certainly nasty. Amazing how fast **** like that can happen. Good luck with the recovery and that rear end.
  26. loudbang
    :eek: Had to smart just a bit.
  27. Thor1
    Thor1
    That's one of those things that will make your **** pucker by just looking at it.:eek:
    Jared, I hope everything heals quickly and well.
    brEad, J_J2, bchctybob and 1 other person like this.
  28. bchctybob
    bchctybob
    Man that ****s, hope it heals up fast and correctly. Best of luck.
  29. Since you are keeping the front suspension there are a couple things you can do if you want to lower it. They make dropped uprights but you can do like Cole Foster does and step the A arms.
    loudbang, J_J2, Thor1 and 1 other person like this.
  30. OUCH!!...so, did you cry? No really, just between us, I won't tell anyone if you did.
    loudbang, J_J2 and Thor1 like this.
