Fired up a fresh rebuilt 348 Chevy today. Installed was an electric cooling fan system. ****ing thermostat didnt open and when I saw the headers starting to glow cherry red I shut it down.It had run maybe 4 minutes tops at around 2500 RPM. Allowed it to cool,ripped out the thermostat and restarted her back up. Al seems well on startup but I am concerned that it may have gotten too hot. It was temperature stable on the restarts (multiple) Any suggestions on what I should look or? Take a fresh compression test?Its not puking water out the headers so I ***ume block,heads,gasket are O.K. Looking for suggestions as too future problems. Thanks,Oldmics
Don't worry to much about it being it is running at steady temps now. I always test new stats in hot water,don't like changing them twice. And rethink electric fans as a lot of them take too hot of temp to start as far as I'm concerned.And if your timing was a bit retarded the headers will for sure glow.
G'day, I've seen headers glow red before without causing any issues with the engine. If you only ran it 4 minutes it would be hard to believe that any damage could have occured. I guess I would watch for any coolant in the oil or vice versa. If nothing shows up, enjoy the new motor. ms
