got me a 1934 ford
Discussion in 'The Hokey Ass Message Board' started by freeze plug, Jul 5, 2012.
  1. freeze plug
    freeze plug
    from Canton, CT
    picked up a 1934 ford on craigslist a few days ago, used to be a 3w coupe but the roof got cut off a long time ago, judging by the aging of that area. Had to have been an old hot rod. It has '53 lincoln 317 V8 coupled to a Hudson 3 speed w/ OD using a custom oldschool homemade aluminum adapter plate. Rear is a banjo with open drove conversion. juice brakes all around. i stuck the 33 commercial grill on there for the time being, it used to have a 30's chevy grill on it. the body is thin is spots, but very saveable.
    frame is Z'd heavy in the rear (super OLD and kinda scary). Front axle is dropped 4-5" and is stretched very thin and flexes really bad, I am replacing it with another '33 axle that is much nicer. can anyone ID this one or is it a homebrew job? Body is channeled 5" or so. It also looks like the rear has been pushed back a bit, probably when the rear Z was done.
    plans are to get the body back into reasonable condition. Some type of duvall/hallock style windshield, cap off the door tops, etc. A smaller radiator is in order, as well as dropping down that grill quite a bit. I also need to remove one head and replace one exhaust valve. It still runs but that onr cyl. has terrible compression.
    Some people have used the "R" word when describing it so I hope to rid it of that soon enough. The first major thing to do is rebuild the front end, it is super sloppy.
    anyways, on to some pics:
    kidcampbell71 likes this.
  2. jazzbum
    jazzbum
    awesome motor!
  3. bubba67
    bubba67
    from NJ
    Dude, I love it ! It's got soul.
  4. Looks like you got you an old hot rod there. Its a good start. If it were me, I would be trying to scrounge up some pieces to put together a top for it to make it a 3 window again later on.
  5. D ROD
    D ROD
    from New Jersey
    Any real 33/34 is worth bringing back. Good on you for scoring!
  6. I see a hot rod coming back to life! I like your plans to bring it back together.
  7. Atwater Mike
    Atwater Mike
    Neat find...lots of potential there.
    Axle looks to have been 'Blacksmithed'...heated, stretched, then hammered on the drop, front and rear... This was an old method, likely done in a kiln and anvil-hammered.
    There are gents looking for 'dated' pieces like this axle, so don't think it's just a $40 or 'give-away' item.
    That open top Hudson tranny can be converted to a 'REAL' floor shift: It's a Borg-Warner, and I believe it would accept a Studebaker pickup shift tower, just by removing the inner shift forks. (check for position of low-reverse slider notch, some of the O.D. boxes reversed the slider, putting the shifter fork notch in front)
  8. Jen......
    Jen......
    very nice score , alot of history there. if it was mine i would be looking to find a top for it to bring it back to a 3 window
    Jen
  9. harleycontracter
    harleycontracter
    Nice piece !!!! Lotta character but I think you need to sell me that motor. lol
  10. KustomCars
    KustomCars
    from Minnesota
  11. studefreak
    studefreak
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    damn...that thing is 9 kinds of ugly...I like it.
  13. 345winder
    345winder
    i agree,,, find a cheap ratty Tudor and cut the top to make it fit!
    awesome find!
  14. I like it. Make it safe and clean it up and roll. A '34 car grille wouldn't hurt.
  15. Philbilly
    Philbilly
  16. Avgas
    Avgas
  17. general gow
    general gow
    MODERATOR
    great score. that taffy front axle is awesome.
  18. ss34coupe
    ss34coupe
    great score! love the motor!
  19. freakin sweet find. I would just get it road worthy tackle the door bottoms and drive its wheels off
  20. shoebox50
    shoebox50
    Great Score!!
  21. Barnmiester
    Barnmiester
    from wyoming
    Nice glad its in good hands!
  22. Shane Spencer
    Shane Spencer
  23. gonzo
    gonzo
    Bitchin. That axle is a wall hanger for sure though. Get it rolling and bring it to the Alter Boys show!
  24. FlynBrian
    FlynBrian
    Nice Score! Have fun with it.
  25. cfnutcase
    cfnutcase
    from Branson mo
    God I need that car so badly!!! Soooo Soooo Badly!!!! Jim
  26. hotrodman3161
    hotrodman3161
    Nice find! If you switch out some parts let me know because I'm trying to finish my 1930 coupe but wanting to find some good old school parts instead of buying things new from a catalog. I look forward to seeing your pics as you make progress on your new toy!
  27. krooser
    krooser
    Don't change a whole lot on that car... it's a rolling hot rod museum.
  28. freeze plug
    freeze plug
    from Canton, CT
    thanks for the replies, i dont plan to change much but the front axle, radiator, and a whole bunch of body work.
    I also need new rear tires, they are H78 and dry rotted. can anyone suggest an alternative size? 760 comparable? should I step up to 800?
    Also, I may try looking into converting this trans to top shift like was said early
    Thanks!
  29. lawman
    lawman
    Very nice !!!! Keep posting.
