History Grandpas el mirage roadster recreation p.r.c
Discussion in 'Traditional Hot Rods' started by paintslinger805, Mar 13, 2016.
  1. So-cal Tex
    So-cal Tex
    Hey Bruce, just in case you don't know you can have your stock 6 volt generator rebuilt to 12 volts charging and still run the 6 volt starter, those OG Henry parts are tougher than people think because I have been running that set up in my AV8 coupe with a 59A in it for 10+ years, only replaced the starter once with another 6 volt version. I like the brighter headlights and easier starting with 12 volts.
  2. The newspaper is so old it just falls apart. I tried to carefully peel it apart to see but it's been in there so long with rain water it's unreadable.
    timmy2times likes this.
  3. image.jpg Just now started working on my intake design. I'm gonna build a 5 carb pyramid set up. Needs all those cfm's. For this 286"er. :D:rolleyes::D:eek::confused:
  4. graveyardsledder
    graveyardsledder
    paintslinger805 likes this.
  5. Gary Addcox
    Gary Addcox
    Just don't look him in the eyes, Dennis. LOL
  6. Gary Addcox
    Gary Addcox
    I'm anxious to see that linkage.
    paintslinger805 and 29AVEE8 like this.
  7. Gary Addcox
    Gary Addcox
    I can't think of anything much worse than having your long, cracked one getting into the radiator. OUCH! LOL Hope Ryan doesn't read this.
  8. Gary Addcox
    Gary Addcox
    Man, you hit the jackpot. I see '46 Ford hubcaps, Model A inside and outside handles, flathead genie with cutout, flathead dizzy. Are those tubs fenderwells for spare tires ? Those might make sweet bobbed fenders for someone.
  9. Yes the guy said they were fender wells but I have a few old sckool Harley's so that's why I got them I was thinking I could use them on one of my bikes.
    Yes is does. Just got back from my new buddy's shop and picked up a few more goodies. 2 scoops are aluminum and one is cast steel. Anybody got one extra cast steel scoop they want to sell me.??????!?
  11. jerseyboy
    jerseyboy
  12. Thanks jersey. I got the fan figured out. I'm sending out my water pumps today to skip down in Florida to have him rebuild them with his turbo fans. I got lots of work to finish over the weekend and next week I get the motor from machine shop. They are ahead on it and they know I need it ASAP for trog.
  13. Gary Addcox
    Gary Addcox
    I am glad to see you and Kevin both get a break. You surely deserve one, or two, or three.
  14. Gary Addcox
    Gary Addcox
    STIR IT UP, BRUCE ! I think you have EVERYONE'S attention.
  15. Gary Addcox
    Gary Addcox
    The deck/rumbleseat lids are one in the same. Not sure about the latches. However, the panel below the deck/rumble lid IS different. The panel for a rumblelid has no upper jam or sill.
  16. Gary Addcox
    Gary Addcox
    Those fender wells would be perfect for a motorcycle. Good thinking.
  17. Oh my. Ready to go. Lincoln 25 tooth zephyr gears with Lincoln u joint. Getting close to vroom vvvroommm day. image.jpg image.jpg image.jpg image.jpg
  18. image.jpg Here's an update on my trunk handle lock cylinder. My key expert hand filed two keys for me. Works like it did new in 32. There is a little tiny pin that holds the cylinder in the handle and without a key you can not get the cylinder out. Also once you stick a drill in the little hole and drill out the pin the lock cylinder will just come out of the handle as the pin is the only thing holding it in. You could make a new pin or have to tap it and put a tiny set screw in. That's why I peeled the skin off. Now I just put it all back together and BAM!!!! Done son..... 32 ford trunk handle I payed more for the keys than the hole box of handles I got.
  19. image.jpg image.jpg :):):D:D:D:D:p:p:p:rolleyes:
    I did have to take some square stock and put it in my lathe and turn it down and thread it to add a 1/2 inch on the handle. Rumble seat lids must have a thicker latch mech. Done son one more check off the list of completion.
    Hypersonic lives!!!!!!!!!!
    303racer and timmy2times like this.
  20. Oh yea machine shop is done with the motor too. Picking it up tomorrow. They Just have to mill the heads .030" to get the magic number of .040" piston to dome height. Happy happy joy joy.
    :D:D:D:D:D:D:D
    timmy2times and volvobrynk like this.
  21. I will get it put together over the next weekend and as soon as skip gets me back my water pumps from Florida I will get her fired up and broke in. Trog here I come. Or should I say trog is coming to me. I will have my sons friend video it so I can share the sounds of a 286"er with all y'all. Wish me luck...
  22. image.jpg Here's an off topic picture of what the California sun looks like when everything around us is on fire. It's almost dark here and it's 5 p.m. :(
  23. Runnin shine
    Runnin shine
  24. Gary Addcox
    Gary Addcox
    Just wunnering ! Is it legal on that there West coast ? ? LOL. Old Dennis may never be the same after TROG.
  25. 383deuce
    383deuce
    I am sure I will never be the same after TROG & my bunk mates.....DAM! the trunk handle turned out great Bruce. I can't wait to hear this beast run.......
  26. Katuna
    Katuna
    from Clovis,Ca.
    Hey, you mind keeping that **** over there please! Left for work this morning at 6:00 and the sun coming up over the Sierras was dark orange. By 9:00 everyone at work was hacking up a lung. I know the rest of Calif. like using the Central Valley as their trash can but, come on!
    Seriously though, can't wait to see the first video of you tearing up and down the street in that thing.
  27. image.jpg image.jpg Sorry got no time to talk. I'm busy.:rolleyes::D:p:p:);):(:mad::confused::cool::p:D:eek::oops::rolleyes:o_O
    timmy2times and Drewfus like this.
  28. dumprat
    dumprat
    from b.c.
    That is pretty!
