Grease or not?
Discussion in 'The Hokey Ass Message Board' started by dasboot3, Aug 12, 2012.
  1. 51plymo
    51plymo
    bobss396 thanks man ill go get some when i work on her next then on too adjusting the damn brakes!
  2. dasboot3
    dasboot3
    So the inner bearing is under that ring in pic#1...right?
  3. 51plymo
    51plymo
    its on the inner side of the drum should be a beveld ring in their holding it in place. trying getting two fingers in their and wiggle it out lol never mind i got small hands Xd
    and bobss396 where do you get that grease at can you but it at like napa,o'rileys,advanced auto?
  4. 51plymo
    51plymo
    i gotta go pick my brothers up from work bobss396 can you give me a private message on where you can buy that grease and have fun with that dasboot3 once its out its pretty straight forward (im 17 shouldnt be too hard for yea:])
  5. bobss396
    bobss396
    Any parts store should have the grease.
    Bob
  6. 51plymo
    51plymo
  7. bobss396
    bobss396
    Yup, you have to pry out the oil seal. Like I said above, they come out with a brake s**** easily. Or use the lazy man's method, also described above. When you work in a shop doing these all day, any short cut saves time.
    Put the drum back on. Thread the spindle nut back on at least 1/2 way. Grab the drum and pull it hard towards you. This pops the seal off and the bearing and seal stay on the spindle.
    Bob
  8. czuch
    czuch
    from vail az
    Nope.
    A flat head screwdriver or anything like that will work fine You'll really wreck the seal pullin it out so just figure on a new one. Theyre $3?? Fun aint it??
    Get new cotter pins too. Another 50 cents is alot of piece-o-mind.
    Just do one side at a time so you still "example A"
    If you end up changing bearings make sure you do the races too.
    Maybe the pictures show the bearing in the race as a unit. Its two piece.
    Go slow, have fun, ask alot of stupid questions.
    Its all easy and hasnt changed much in a long time.
  9. bobss396
    bobss396
    I think I'd want to replace the seals on a 58 year old truck, or any time bearings are removed. Bearings come with the races and if you know the tricks, they come out easy, going in is another story. I have an old set of races with the outer diameters ground down and I use those to drive the new ones in.
    Bob
  10. Incarnation
    Incarnation
    If it has not been stated, make sure to period correct grease.
  11. dasboot3
    dasboot3
    "If it has not been stated, make sure to period correct grease."
    Wadayamean???
    And how do I get the oil seal back in?
    Hammer and wood block?
    Or just smack it back in?
  12. bobss396
    bobss396
    I think "period corect grease" was meant to be funny. There are seal drivers, but I just tap them in gently with a hammer. The wood block will work.
    Bob
  13. dasboot3
    dasboot3
    Thanks bobss396!
    Rickybop has been givin' me pointers on the side and with you guys helpin out I think I've got yhis thing figured out.
    Really quite simple when ya know what to do.
    Like everything in life!!!!!
    I thought the seal was actually part of the hub itself.
    Thank you all again!
  14. You'll never learn if you don't make a mistake here and there.
