Technical greasing tool
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Nov 14, 2016.
  1. tb33anda3rd
    tb33anda3rd
    DSCF0009.JPG DSCF0010.JPG DSCF0011.JPG found this while helping a friend clean out a barn. appears to be used to grease the annoying "nozzle" style grease fittings.
    the odd thing is why does, the screw have to be removed? it slides out of the slot at the bottom, so it needs to be closed to get it together.
    any body ever use one? when would it be handy?
  2. seb fontana
    seb fontana
    from ct
    I be curious so giving a bump..
    tb33anda3rd likes this.
  3. blowby
    blowby
    from Nicasio Ca
    Perhaps there were additional C clamps available
  4. tb33anda3rd
    tb33anda3rd
    ahhh, that makes sense! different lengths!
  5. chevyfordman
    chevyfordman
    I'm interested also
  6. The37Kid
    The37Kid
    Come on, you're a Chevy guy with leaf springs to lube, post some photos of it in use. Bob
  7. Binger
    Binger
    from wyoming
    Interesting tool. My guess would be its from the early 30's. That bayonet Alemite fitting on the end was popular about that time.
  8. tb33anda3rd
    tb33anda3rd
    hah, i don't think i ever had a chevy with those dopey grease fittings.
    the next model A that comes in i will try it.
  9. Engine man
    Engine man
    from Wisconsin
    Greasing king pins and leaf springs.
  10. ct1932ford
    ct1932ford
    Looks like it would be good for cracking walnuts on Thanksgiving!:p I do like the red.:rolleyes:
    deucemac likes this.
  11. oldolds
    oldolds
    You might have to take it apart to get it on some fittings depending on location. I think that tool is used to get grease into zerk style fittings (no ball, straight) when you can't get grease in them. The grease gun locks on the fitting (alemite?) so you can get more pressure without popping off. Before modern ball style fittings.
  12. chaos10meter
    chaos10meter
    from PA.
    Maybe its for installing zerk fittings
  13. Homemade44
    Homemade44
    My guess is that it is an installation and removal tool for some type of grease fitting. You turn it end for end depending on what you are trying to do, push or pull.
  14. tb33anda3rd
    tb33anda3rd
    it would probably work to install them, but i think the prime use is to hold it tight for stuck or clogged fittings.
    i look forward to using it.
