Green Bean Motor .....a look into the future
Discussion in 'The Hokey Ass Message Board' started by Antibilly, Nov 18, 2003.
  1. Antibilly
    Antibilly
    the future of The Draglinks cc Hot rod to be known as the "Green bean"
  2. Antibilly
    Antibilly
  3. Levis Classic
    Levis Classic
    Do you snap it to remove or does it snap you?!!
  4. Fat Hack
    Fat Hack
    from Detroit
    You sick FIEND!!!! [​IMG] [​IMG] [​IMG]
    Cool shit, man....Green-O-Rama Grooviness all the way! [​IMG]
    Kermit Kustoms Kar Kulture Klub 2003!!! [​IMG]
  5. Antibilly
    Antibilly
    I must say I snap it
  6. Cannibal
    Cannibal
    you need to put some "remove before flight" streamers on the end of those pipes [​IMG]
  7. Antibilly
    Antibilly
    all that flash and Im under the idea its a good motor??? the preasure Im under huh?
  8. burger
    burger
    What're the specs on it, Mike?
    Ed
  9. Levis Classic
    Levis Classic
    Im sure being the gold chainer you are - its all about the show not the go anyways!
  10. Antibilly
    Antibilly
    its a super dooper SBC 305 high rev mid 80's anit smog motor!
    Got it from a customer who said it ran great when removed....I went through it and everything looks clean and ready to run!
    new water pump, fuel pump, carb, headers(duh), plugs,dist, VCer's, alt, pulleys, oil pan, starter, and the removal of everything not needed to run like a bitch [​IMG]
  11. burger
    burger
    Roller cam engine? How 'bout you slide that into the Apache before you put it on the Autotrain? [​IMG]
    Ed
    PS- Are you going to paint the block to match?
  12. Zor
    Zor
    from Phoenix
    looks good mike. how close are you to installing that emerald on crack?
  13. Antibilly
    Antibilly
    well Zor the parts list is coming to an end. I got a 57 chevy rear end.........So Im down to a trans, spindles, frt brake kit and Ill start building the roller...everything else is there down to the bolts!!
    No Cam and I dont give a damn.........no the block will be factory steel and oil in color!
    the frame and body will match the "GREEN BEAN tm" green as seen on the motor [​IMG]
    black wall wheels, black wall cheaters and skinnys up front
  14. Nads
    Nads
    from Hypocrisy
    Looks good, but like I said those zoomies are an instant cop attractant, especially in our tight assed burg.
    How about this fucked up weather today Mike?
    Whaddafuck, it was lovely yesterday!!!!
  15. Antibilly
    Antibilly
    Nads, This town is REALLY easy on us you have to admit!...as for the weather its getting ready to freeze up for the turkey rod run!
    and again Ill pass your packford with or without cool guy Zoomies!!
    Slow Shifter!!!!!!!!!! [​IMG]
  16. Boones
    Boones
    from Kent, Wa
    Hold On... keep the weather warm for the Run. I am coming south for some sunshine... See you guys in a few days..
    Did you do a club parking and do you have the swap space?
  17. Antibilly
    Antibilly
    DragLinkscc Vendor spaces om row 55
