Green primer question
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Sep 18, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    What's the most popular green primer color I see alot on some of these cars,I need to know the brand ,Someone I know wants to primer and sell his car in this color.
  2. Master of None
    Master of None
    Most likely its DPLF made by PPG its called a gray/green epoxy. Not sure what number it is 90 is black and 70 is red i think.
  3. millersgarage
    millersgarage
    Are you asking about etching primers?
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Dont know .Just go to shows and see alot of green primer cars .Like I said its for someone else .
  5. Jeff J
    Jeff J
    DP40 I believe is the number from PPG
  6. Recon
    Recon
    from Smyrna Tn
    DPLF Epoxy Primer comes in 6 colors;
    DP40LF (Gray–Green), DP48LF (White),
    DP50LF (Gray), DP60LF (Blue), DP74LF
    (Red Oxide), and DP90LF (Black).
  7. guiseart
    guiseart
    It may also be paint, there are a lot of good flat olive drab greens out there these days.
  8. crash11049
    crash11049
    could it be the military green primer used on aluminum ?
  9. scrape53
    scrape53
    from iowa
    do you have a pic of something wearing the color you're after?
  10. chryco
    chryco
    from Winnipeg
    "Green" primer is zinc chromate and will stick to all metals . Provided they are clean.Great for painting chrome or stainless trim pieces.
    Chryco
  11. Write these down, they are correct.
  12. zman
    zman
    from Garner, NC
    HOK epoxy primer is also green...
  13. ride00007
    ride00007
    from Illinois
    Yep... that's the green primer that comes to mind first. It's good stuff.
    KP2CF ... parts A and B
    The color is about like a Fannie May mint meltaway.
  14. concreteman
    concreteman
  15. MedicCustoms
    MedicCustoms
    [​IMG]this is a military water base epoxy I just bought some off of *-bay got 2 gal for 60 bucks shipped :eek:.... hope it helps:cool:
  16. Matlack
    Matlack
    DuPont has 2580CR epoxy that is green.
    2510s- light gray
    2540s- med gray
    2570s- dark gray
    2590s- black
    Just about every paint company has colored epoxy primers- just remember that all epoxy primers fade out in the sun. You might try using flattened urethane topcoats. You can get the auto paint store to match it to the color you want. If price is an issue try an industrial flat topcoat. Most large auto paint stores carry industrial paint also.
  17. deadendcruiser
    deadendcruiser
    Heres a shot of the HOK kp2cf. Fills great a bit pricey but worth it.
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Its the green gray Thanks
