greetings from the great southern land
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by aussie34, Apr 10, 2005.
  1. aussie34
    aussie34
    Hi there
    I have 34 ford 3w coupe gl*** body 302 c6 9 inch rear shortened
    Picked it up as an unfinished dream has mits 300 front end
    need as much info as I can get as 25 years since last effort
    38 chev 307 powerglide 10 bolt salisbury
    I have an old 323 mazda as a donor car
    need to know what bits are useful
    Need to set up 4 bar rear end
    Get all ch***is right before body
    want to do most stuff myself good basic knowledge no expert
    Any help appreciated
    Col
  2. Sticher1
    Sticher1
    from Ct
    Welcome from Ct
  3. coupe5w36
    coupe5w36
    Welcome from another Melbournite. Coupe sounds good. Mazda should be able to provide a steering column for starters. Are you planning full rego or SR plates? I'd check with an engineer before going too far if you want full.
  4. CathyH
    CathyH
    Welcome from Oklahoma! CH
  5. aussie34
    aussie34
    Planning for full rego hope to use as daily driver
    had no problems with the 38 chev back then it was a lot tougher than now it seems.
  6. Louver Dude
    Louver Dude
    Welcome Aussie, From Wisconsin and a third generation removed Aussie
  7. striper
    striper
    Had my first meeting with engineer yesterday regarding my 28A modified. Very worthwhile couple of hours. Given me a renewed enthusiasm and some direction to take. They're not there to knock you back, they're there to help you make it happen. Also, they have the magic pen that can get you on the road. If you haven't got this do***ent yet check out www.dotars.gov.au and search Street Rod. It's the national construction guidelines (very similar to the $40 ASRF book)
  8. coupedevil
    coupedevil
    Welcome to the HAMB!!!!
  9. aussie34
    aussie34
    Thanks for the reply I have joined ASRF and I have downloaded the dotars manual
    Having made mistakes before I will be a tad more cautious with this project and take my time Have to check out what the previous guy has done and make sure its up to the mark He was pretty fussy and being a boilermaker/welder his work looks very pro Dont think I will attempt to do the welding myself maybe just get things set up and tacked into place then get a pro to finish the job
  10. Big D
    Big D
    Greetings from another FNG from Pa, welcome to the HAMB BIG D
  11. Outback
    Outback
    from NE Vic
    G'day,
    Welcome aboard, from another Aussie, Hope you enjoy your stay,
    coupe5w36 has lots of good advice and contacts around Melb.
    Cheers
    Outback
  12. aussie34
    aussie34
    You sound like you have a fair amount of experience and reading your profile I am the same having been away from rods 25 years or so
    I need to fit a parallel 4 bar in the coupe and mount a front rack and pinion to L300 front end Any suggestions? Who makes a reasonable 4 bar and who can ***ist with the steering fitting.
    How goes your project? What stage is it at? regards Col
  13. Col. You'll probably find more ***istance on the Aussie Cruizin' site or the Aussie section of the RRT.......unless we can persuade you into some style by binning that L300 and rack and pinion!! The HAMB concentrates on hotrodding with an older, more faithful twist.
    http://www.cruizin.com.au/newforum/category-view.asp?catlock=1
    http://www.roddingroundtable.com/forums/
