Hot Rods GRENADED MY DIFFERENTIAL!!! Check this out...
Discussion in 'The Hokey Ass Message Board' started by Doctor Destructo, Jun 15, 2009.
  1. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    A hole in anything that, as a result, leaks major amounts of oil, always makes a good story years later.
    You're just building up your library of good beer drinking stories.
    Always look at the positive!
  2. Hemi325
    Hemi325
    from Boerne, TX
    I did the same thing last Fall with a 58 Chevy P case. On mine, the carrier cap broke, the carrier whanged around in there lunching the ring and pinion and knocking a hole in the case like yours. When I rebuilt it, I imade up some bafffles for the axle housing which will help keep lube in and around the 3rd member rather than out at the ends of the axles. The diff is in a road race car.
  3. HotRodDrummer
    HotRodDrummer
    My 1980 Pinto and I were at the track one weekend when my dad was out of town, so being the young punk I was I dropped the exhaust at the shop and drove it to the track about thirty minutes away. I had made a couple p***es and always fought the tune on the carburator, I had an old guy (I was 17 at the time) come over and he was telling me how to adjust the carb in (it was obvious I was not a mechanic), so we got it all tuned up and I got in line. Did my burn out, Staged got the rev's up to 2800 and launched!! Holy ****! that thing launched like I had never felt in my life! Before I knew it the tach read 5500 and I popped it into second gear.
    All of a sudden it sounded like Billy Bob shot his 30-06 from inside the car! The pin that holds the spider gears in place had twisted clean apart!
    Needless to say I thanked the old guy for helping me fix the carb tune and he offered his trailer and truck to get the car back to the shop!
    BTW, 1980 Pinto, Moser built 9" w/3.90:1 posi, 351w dart heads 1.6 rockers, ***** cam and not much of a converter. best I ever ran was a 13.20 @107 and change. If it hadn't granaded the rear I was working on a 13 flat.
  4. Duntov
    Duntov
    I did exactly the same thing to my '59 Chevy Impala 4.11:1 rear end when practicing a burn out in front of my house. The shrapnel hole looked about the same size and shape as that one. After I pulled the rear end, it gave me the opportunity to install a third member with a lower gear. I installed rebuilt third member from a '64 Chevy (no difference) with a new set of 4.56:1 gears. That rear end lasted for another five years of hard drag racing using a factory 1965 327 CI-365 HP FI Chevy short block in my '59 Impala with "520" Power Pack heads with larger valves and ported by Joe Mondello. I was racing in AHRA F1-E/HR cl***. F1= multiple carbs. (2-4 barrel AFB) .
  5. racer756
    racer756
    Threw the rods out of a rearend, You sir are bad***!!!
  6. LowKat
    LowKat
    Now, that's a trophy
    I manufacture and collect mangled parts......
    my best one:
    late 1963 427 Ford crank/block/pistons/rods in my boat
    I think it broke a cam and dropped a piece into the reciprocating ***embly at about 5500 rpm but the engine was so torn up, hard to tell what caused it.
  7. tiredford
    tiredford
    from Mo.
    I want a Doctor that drives a hotrod. My Dr. drives yuppy Jap convertable piece of ****.
  8. OGNC
    OGNC
    Damn, that is one hell of a vent hole!
  9. a little preparation H and a maxi-pad.. it should **** right back up.. aside from all that... good job..
  10. bonesy
    bonesy
  11. Crazydaddyo
    Crazydaddyo
    Don't throw that old unit out!!!!!!!!!
    I read on a thread here on the HAMB that that third member can be fixed with dryer sheets.
  12. patrick66
    patrick66
    That is too friggin' cool! I've never seen a pumpkin blown like that! That is a keeper for the "wall o'broken ****" to show your friends! Glad to see it did not cause a wreck or anything like that! Spectacular destruction of parts is always a neat thing to see...as long as it isn't my parts!!!
  13. Jeff Walker
    Jeff Walker
    Yep, it's broken.:D
    But why is it us gearheads are always so proud of the carnage that we often created??:confused:
    Heck I still have two hurt pistons and a broken piece of an axle laying in my tool box that were from my brief circle track career. And that was 25 years ago!!!
  14. yoyodyne
    yoyodyne
    Good job!
    This is out of my FED. Also an early chevy rear, with one broken tooth.
  15. Doctor Destructo
    Doctor Destructo
    You should see the Doctor's Parking Garage. Today I parked my 31 coupe between a Toyota Prius (on the left) and a Ferrari 430 Spyder (on the right). The Prius driver is a dweeb, duh. The guy who owns the Ferrari was complaining the other day that his mandatory oil change cost him $1800. When I presented him with the list of vintage speed parts I could buy with that coin, he just looked at me and made some comment that sounded like Mike Myers doing the "Sprockets" routine from SNL. So I got up and and left him in mid sentence.
  16. red baron
    red baron
    from o'side
    Doctor Destructo, are you in north county?
  17. heliotropephotos
    heliotropephotos
    from Austin, Tx
    I killed two of these! not like that though! Was doing a burn out with to really fat friends in the back seat and spun the spider gears out of it! took the axles out and this really nice "silver paint" came out of the tubes. Good job doc.
  18. torchmann
    torchmann
    from Omaha, Ne
    Hey easy on the fat jokes twiggy:)
    I concur, JBweld and dryersheets and a gallon of STP.
    lost a spider gear on a 66 chevy c10 went straight out the housing and took out a tailgater's radiator.
  19. LOST ANGEL
    LOST ANGEL
  20. cgaswillys
    cgaswillys
    from New Jersey
    Ouch, racing will do that. I blew the pinion gear right out of my 57 Olds rear a few years ago at the track. Left a big hole in the pumpkin and also bent a brand new chrome moly drive shaft. I did at least get a laugh when the track crew pushed me off the starting line and one of them tripped over the pinion gear.
  21. slefain
    slefain
    from Atlanta
    Yup, I cracked a non-Hamb friendly rear diff once. Somehow sheared a ring gear bolt and ****ed it up into the pinion. Ker-POW! Dad reminded me that a Lincoln is not meant to be drag raced, I just offered him a drink....
  22. I blew a hole in the housing in my 61 pontiac, a canadian model they run the chevy rear end
  23. autobodyed
    autobodyed
    from shelton ct
    a doctor that blows **** up! cool.
  24. Rice n Beans Garage
    Rice n Beans Garage
    Oh Well, Time to sell your coupe, how much ????????
    Just kidding I remember the car when it was in primer with the orange grill shell, you really made it *****inn !!!!!!
  25. C'mon, admit it... You were wearing a Wolf Shirt while driving it!
  26. Doctor Destructo
    Doctor Destructo
    Mount Helix (Good ole East County).
  27. Lucky it didn't lock up. Only ever killed one rear end, custom built ad supposed to handle over 2000hp.
    I managed 3 ft of movement in a factory driveway before gear parts exited through the sheet housing. 2000hp my ***! We were lucky to be punching above 1800hp!
    They made me a new one and sent it over free of charge though.
    Doc.
  28. Yep, I found some bent pushrods from my old Duster the other day:)
  29. pan-dragger
    pan-dragger
    wow nice little hole.
    here is mine, it spit the pinion out.
  30. OGNC
    OGNC
    I grew up in East County. Graduated from Santana High School and went to Grossmont College and then took cl***es at SDSU - but that was a lifetime ago...
