Projects Grille badges
Discussion in 'Traditional Hot Rods' started by angelbaby65, Mar 5, 2023.
  1. angelbaby65
    angelbaby65
    Hi guys, I’m looking to have a few custom grille badges made and striking out with no luck. Anybody have any insight on where I could get this done? Thanks in advance!
  2. Rocky
    Rocky
    Classified Editor
    BADGES! We don' need no steenking badges!
    1pickup, jimmy six, da34guy and 12 others like this.
  3. 51504bat
    51504bat
  4. denis4x4
    denis4x4
    from Colorado
    Check the Hemmings cl***ified ads
  5. It would be helpful if you could post a couple examples of what you have in mind.... 'grille badges' could cover a lot of ground. There are a ton of super talented people on here that may be better able to offer advice/sources if they knew what your expectations are.
  6. woodiewagon46
    woodiewagon46
    from New York
    As '28 points out you need to get a little more specific. Grill badges come in cast metals, (br***, aluminum etc.), stampings, hand painted, vitreous gl***, etc. The more you order, the less per piece they cost. What exactly are you looking for and how many do you need?
  7. chrisp
    chrisp
    You could photoetch some br*** or aluminum then apply some enamel, especially if it's for a one off.
  8. rudestude
    rudestude
    Look online there are several manufacturers for them ,made to order using your design just for you, from cheap **** to ones for your Rolls-Royce.
    Here's one...arniebrown.com custom car badges
  9. Deuces
    Deuces
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    Or a good-reputation hobbyist, maybe from Etsy, if you can't find one sorta-local? IDK...
    MArcus...
  11. HOTRODPRIMER
    HOTRODPRIMER
    Paul (wex65) posted this on the Gentlemans Coupe build, as I remember a started with a '32 Ford Bob Drake emblem and sandblasted it and then had it etched by a engraver. HRP
    Deuces, chrisp, chryslerfan55 and 2 others like this.
  12. Illustrious Hector
    Illustrious Hector
    I made this one out of a lapel pin and commonly found shop ingredients 20230204_101052.jpg
    Hellfish, Just Gary and Deuces like this.
