Technical ground clearance for oil pan
Discussion in 'Traditional Hot Rods' started by Harley Charley, Mar 25, 2023.
  1. Harley Charley
    Harley Charley
    what's a safe ground clearance for the oil pan?
    dana barlow likes this.
  2. twenty8
    twenty8
    Define "safe".
    You will get a lot of different opinions for a question like that.
    My mind says 5 inches.....
  3. evintho
    evintho
    There's 4" on my roadster.
  4. Harley Charley
    Harley Charley
    So, I'm @ 3" inches now, and I'm not comfortable with that. I just put a 502 in it, and I'd like to keep the oil in the pan where it belongs. It's got a 5" drop axle and I put a pretty chrome spring with reversed eyelets on it. I really don't want to buy another axle, or spring, but It's a lot cheaper than another bullet. I would like another inch. Any suggestions?
  5. lake_harley
    lake_harley
    More than if your car was on the wheels with no tires.
    Lynn
  6. Budget36
    Budget36
    Well above the scrub line. Speed bumps with the suspension going up and down can ruin your day.
  7. deathrowdave
    deathrowdave
    from NKy
    Mine is stand a hard cigarette box on its side , clearance . Don’t smoke , no idea what the measurement is . Lowest point is right behind the front axle . Front sump Ford engine
  8. All you really need, is 1/8 inch to be safe! ;) Impact with road surface is no good at all.
  9. lostone
    lostone
    from kansas
    Depending on the vehicle, add some arch or extra spring if it's a leaf spring front end. Probably the cheapest and easiest way to go.
  10. hemihotrod66
    hemihotrod66
    As much as you can get.....
    Bob Lowry and Desoto291Hemi like this.
  11. swifty
    swifty
    Depends on a few things - condition of the roads you plan to drive on, location of your sump plug, firm or soft suspension. Here in Australia we have to have a minimum of 4" clearance for everything to get full or street rod rego. I've got 4" on my coupe and no paint on the bottom of my sump from driving up country driveways so I'd say 4" minimum. Oh and my sump plugs at the back of the pan.
    Desoto291Hemi and Lil 32 like this.
  12. Harley Charley
    Harley Charley
    I wonder if I let the air out of the tires on 1 side, to get a general idea? I know it's a stationary measurement without the car bouncing, but it beats running over a set of spike strips and finding out the hard way! I gotta quit watching Cops...
    Thanks! I thought 4" would be about the right #. After all, It's kept my wife happy for the last 20 years...
    SS327, spudshaft, Special Ed and 2 others like this.
  13. 56don
    56don
    Taller front tires
    Special Ed and seadog like this.
  14. Harley Charley
    Harley Charley
    Thanks, 56don, but i've got the tallest tire I can find for my 15" rim. Maybe I could find a taller front in a 16"?
  15. iagsxr
    iagsxr
    What do you have for an oil pan now?
    Could you use a dragster or low-clearamce circle track pan?
    seb fontana likes this.
  16. dana barlow
    dana barlow
    from Miami Fla.
    I'm at 3in.,but that's fairly close to front wheels* an front sump pan,, plus there is a 1/8 inch steel skid plate welded to bottom of oil pan.
    Been this way for years,did ding it a few times.
    Your Q,is a lot about what type roads you drive,an looking out well,also 4in. to 5in. would be much better. DCYFAIRShow.jpg
    Blade58, Desoto291Hemi and Lil 32 like this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    5" & I've still s****ed it a few times , can you put a spacer between your spring & mount ?
    dirt t and 2Blue2 like this.
  18. Kiwi 4d
    Kiwi 4d
    Could you add a skid plate ,when you have raised it some?
    26 T Ford RPU likes this.
  19. evintho
    evintho
    I too was uncomfortable at 3". I got to 4" by raising the motor another inch.
    Motor mount at 3".........
    Added a 1" length of pipe to the mount, raising the motor.......
  20. '29 Gizmo
    '29 Gizmo
    from UK
    Swap out the bottom leaf of the front spring for a standard one. Or put a spacer, or extra short leafs between the spring and crossmember.
    Another option is a Milodon low profile oil pan.
    Depending on how stiff your spring is and available stroke on the shocks you could get 2-2.5" of bump travel.
  21. Mr48chev
    Yuppers. Busted the pan on my T bucket on a speed bump and a raised man hole cover the next time. Left and oil streak down the street on that one and my buddy had to tow me to the shop we worked at and he made a couple of phone calls and got me another pan.
    Wheel base may have had something to do with it,
    Butler 32, reagen and Desoto291Hemi like this.
  22. Wives' will lie a lot to get credit cards!
    X-cpe and Desoto291Hemi like this.
  23. Jmountainjr
    Jmountainjr
    A picture would help, but hard to imagine just 3" of pan clearance and it being above the scrub line. But as been mentioned, you've got a number of options, chrome issues aside: axle with less drop, different spring, spacer above the spring, motor mount shim, lo profile oil pan. Depending on your front X-member depth, the spring shim and maybe a motor mount shim are the cheaper, easier, quickest fixes if they get you enough clearance. Good luck and let us know what you solution you use.
    Ned Ludd and mad mikey like this.
  24. Bandit Billy
    Bandit Billy
    I have a buddy that built his car the way he liked it, pretty aluminum oil pan on a dual quad SBC. He tore the bolt out of that pan on his car trailer loading it up to go to the muffler shop. Too low can really harsh your mellow, man.
    SS327, Butler 32, ekimneirbo and 2 others like this.
  25. Jalopy Joker
    Jalopy Joker
    a lot depends on suspension travel - just jumping on frontend does not equate real world road travels - areas that have a lot of up and down rolling hills can create a momentum that will cause suspension to drop more than on a flat road. even the covers for the refueling points in ground at gas stations can cause plenty of problems
    mad mikey likes this.
  26. twenty8
    twenty8
    ..... and then there are the dangers that have nothing at all to do with suspension travel. Speed bumps, raised driveway entrances, debris on the road, etc can s****e the barnacles off your oil pan no matter how slow you go.
  27. mad mikey
    mad mikey
    Roads are horrible here in Pa. , yours may be better and that should be a condition too evaluate. My rule here is 4 to 5 inches providing your suspension can handle it , and on the stiffer side.
    rod1, Desoto291Hemi and twenty8 like this.
  28. pprather
    pprather
    My pan sump is just over 4" above the ground. About the same as the center of the I beam axle. Sixty thousand miles without a scratch on either one.
    rod1, mad mikey, 2Blue2 and 1 other person like this.
  29. twenty8
    twenty8
    Awww, man, you know you shouldn't have said that...... That Karma gal has big ears.....:eek:
  30. pprather
    pprather
    Only if four inches is not enough.
    On another note, someone above referenced a cast aluminum pan. This is much less forgiving then a stamped pan, if slight ground contact is made.
