Technical Grounding Cylinder Heads?
Discussion in 'The Hokey Ass Message Board' started by Truck64, Oct 27, 2017.
  1. Truck64
    Truck64
    from Ioway
    Replaced the engine ground battery cable to block, and starter ground cables etc., with some heavy duty types, so had some extras laying around. What the hell. As an experiment bonded both heads together and ran a cable direct to the neg. terminal on the battery. Danged if it doesn't seem to run more solid at highway cruise and under load. Is it just my imagination or is there a benefit to doing this?
  2. 302GMC
    302GMC
    from Idaho
    The older the vehicle, the more important grounding everything becomes.
    Truck64 likes this.
  3. Blues4U
    Blues4U
    from So Cal
    There should be plenty of continuity between heads & block via the head bolts. Besides, what electrical components do you have grounded to the heads?
    Truck64 likes this.
  4. Truck64
    Truck64
    from Ioway
    I agree it "shouldn't" be necessary. The only electrical components grounded to the heads are spark plugs!
    Blues4U likes this.
  5. lothiandon1940
    lothiandon1940
    I think it's one of those deals where when you wash your car it always seems faster than when it was dirty.:D;)
  6. Rusty Karz
    Rusty Karz
    Well, it sure can't hurt and proper grounding is certainly important. A little redundancy is good insurance.
    Truck64 and lothiandon1940 like this.
  7. Atwater Mike
    Atwater Mike
    Just being 'presumptious', I'm gonna take a shot in the dark and guess this V8 (whether or not it's a flathead) has a negative grounded battery.
    But you said it 'ran more solid', so I gather it didn't let the smoke out of the 'box'. So...perish the thought.:D
    Truck64 likes this.
  8. Blues4U
    Blues4U
    from So Cal
    Haha! You know, it never occurred to me about the spark plugs grounding thru the heads. I was thinking about electrical components such as the starter, etc. Duh!
    Still, I do think there should be plenty of continuity thru the head bolts for electrical currents to flow from the heads to the block.
    lothiandon1940 and Truck64 like this.
  9. Truck64
    Truck64
    from Ioway
    Yeah I'm no drag racer, just like to get these old things running good, as advertised. It looks like from digging around the 'net that aluminum heads are supposed to be grounded. Guesss I'm not the first to think of this, imagine that. Some claim that even iron heads might not be grounded as well as they might be, because of gaskets, ***embly grease, loc***e, corrosion on fasteners, etc. "Continuity" as such really doesn't tell you much.
