Hot Rods GTO engine swap
Discussion in 'The Hokey Ass Message Board' started by gary arvan, Oct 30, 2022.
  1. gary arvan
    gary arvan
    What frame mounts and engine mounts are required to install 454 chevy big block in 1964 GTO. Any tech help would be appreciated , as i only want to do this once! lol. Thank you in advance.
    arkiehotrods and Brian Penrod like this.
  2. Good way to ruin a GTO
    scoop, Ned Ludd, Rolleiflex and 28 others like this.
  3. catdad49
    catdad49
    Tman, would not be my first choice, but that may be a lot easier! Check mounts for a Chevelle, basically the same under the skin.
    Jacksmith and Deuces like this.
  4. uncleandy 65
    uncleandy 65
    Can't you find a Pontiac motor anywhere?
  5. PackardV8
    PackardV8
    Yes, some of us believe a Chevy swap can ruin anything. We cringe when on MotorTrendTV the answer to everything is "LS crate motor."
    There's want-to and there's have-to. Years of experience prove BBC horsepower costs about half as much as Pontiac horsepower. And unfortunately, if handling is the goal, again LS horsepower does it all.
    Maybe, decide on your goals and your budget.
    Jack Vines - ask me how much Packard V8 horsepower costs
    warbird1 and vtx1800 like this.
  6. MeanGene427
    MeanGene427
    from Napa
    That would be an awful shame, *******ing a 64 Goat just because it's "cheap"
    triumph 1, Ned Ludd, warbird1 and 7 others like this.
  7. gary arvan
    gary arvan
    keep negative comments to yourself, please.
  8. MeanGene427
    MeanGene427
    from Napa
    This one still has Poncho power- and is pretty rapid
    triumph 1 and rmcroadster like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, Chevelle mounts will work, and to all you nay sayers, when the hell did the Hamb change from a hot rod forum to a restoration forum? I say go for it! there are enough stockers in the world so there is no danger of forgetting what they look like....
  10. squirrel
    when did it change to a muscle car forum? :)
    scoop, Cosmo49, INVISIBLEKID and 29 others like this.
  11. jimmy six
    jimmy six
    I agree. Use Chevelle parts. Your not the first. I would paint it the Pontiac metallic light blue if were me..
  12. Once again it's the Hamb to the rescue. Guy asked for TECHNICAL ADVICE and starts getting an *** load of opinions. Moriarity had to take his finger off the delete key to answer the guys question. You want your Goat fast for a third of future money spent, it's a BBC all day long with Chevelle mounts.
  13. RmK57
    RmK57
    429-460 Fords are cheaper, more plentiful than a BBC. Maybe look into one of them.
    ffr1222k, Deuces, lemondana and 3 others like this.
  14. squirrel
    then he'd have to cut off the front frame, and put an axle under it, and those cars look funny like that.
  15. MCjim
    MCjim
    from soCal
    Jim Wangers use to jokingly say something to the effect of: "the secret to make your GTO faster is put a BBC in it"...
  16. catdad49
    catdad49
    Not a thing Wrong with engine swaps, lots of Old Fords with other things in them. Most swaps are based on cost and availability, some just to be different. Rocky prefers Poncho Power as an example.
    bschwoeble likes this.
  17. Lone Star Mopar
    Lone Star Mopar
    Purists be damned, Hot Rod that thing and leave the naysayers to argue with each other on the internet !
  18. deathrowdave
    deathrowdave
    from NKy
    I would not do it , but it’s your car do what you will enjoy . And yes chevelle stuff makes it a bolt in process
    MARKDTN likes this.
  19. mohr hp
    mohr hp
    from Georgia
    Wow, HAMB showing it's colors! About the actual question, all GM A- bodies use the same basic frame. Watch out for chinese reproduction motor mounts; I put a BBC into my brother's '65 Chevelle, and the thru-bolt holes were so far off I couldn't use them. Ended up buying some good old U.S. made real GM parts.
  20. 38Chevy454
    38Chevy454
    I don't think the HAMB is being a restorer forum. The guy got his answer.
    I think what people are commenting is that it would be cool to see Pontiac power. We like older engines here. Pontiac has some great history of strong engines. Non-Chevy engines cost more to build, no argument there.
  21. Eggzactly! Dude might as well go LS if he wants Chevy AND cheap power.
    Pontiacs, Caddys, Buicks and Olds need their respective engines.
  22. hemihotrod66
    hemihotrod66
    Really put an axle under my 65 and didn't cut the frame....And if marriage had not gotten in the way this would have had a 426 hemi.... My 1965 GTO.jpg
    J.Ukrop, Al T, moparboy440 and 6 others like this.
  23. DDDenny
    A high school cl***mate put a stock 396 in his GTO in 1971.
    Ran like a scalded dog!
    dirt t, Tickety Boo and AHotRod like this.
  24. squirrel
    you didn't put a front sump engine in there, though.
  25. Budget36
    Budget36
    I wonder what the difference is in building a BBC vs a large Poncho is? I looked a few years back, heck even bearings seemed to be twice the cost of a SBC, pistons I shuddered at;).
    But if you have a good, decent running 454 and a car that needs an engine, get it done.
    Might even be ahead $$ wise if you don’t have a 389, etc, but have a BBC.
    But will the Pontiac bell/trans bolt up from that era? Might be an added expense.
    Deuces likes this.
  26. 1biggun
    1biggun
    Meh .
    As long as its not a primo restored 100 point Goat and he dosent butcher it up it all can be put back someday .
    Unless he's racing it I certainly would just stay Pontiac. Rare expensive car these days. Chevelle stuff will fit . Headers should clear everthing.
    Never did a BBC in a early Goat but did several SBC Into 69 Lemans copy . Was bolt in . Took all the mounts off a chevy wagon .
    Can't recall if the heater box clears the BBC or not on those ?
    Run a chevy trans/ bell housing or adapter plate to the Pontiac trans . There cheap.
    Some pics of the car would be nice .
    ffr1222k and firstinsteele like this.
  27. squirrel
    if you put a big block chevy in it now, it's halfway to the LS swap it'll get from the next owner
    48fordnut, thark, ffr1222k and 3 others like this.
  28. Pete Eastwood
    Pete Eastwood
    from california
    Use a chevy bellhousing, they're easy to find. The Pontiac trans should bolt up.
    Moriarity likes this.
  29. Muttley
    Muttley
    If he's going to go that route he can use the savings to buy some high heels and a feather boa.
  30. dirt t
    dirt t
    I get frustrated with all the BS.
    He asked what was needed, not for an opinion.
    Please stay focused on the question.
