Projects Guernsey boys model A coupe build.
Discussion in 'Traditional Hot Rods' started by Guernsey boy, Feb 1, 2011.
  1. Really nice work!!
  2. alright mate! i've been meaning to email you for ages. thanks for the kind words :)
  3. lets be honest, drilling shit full of holes is cooler than not drilling shit full of holes.
    this piece might look a tad heavy duty just to hinge the trunk from, but it'll also serve as a mount for the back rest of the seat and probably part of the mounting for the gas tank.
    catdad49 and Joemama like this.
  4. billys54
    billys54
    Really nice work
  5. Cross Rodder
    Cross Rodder
    How many gallons of cutting oil have you gone through...ha ha
    Nice work!!!
  6. Kustom Dick
    Kustom Dick
    from Finland
    True....
  7. lorodz
    lorodz
  8. Big Russ
    Big Russ
    Nice work! Very inspirational.
    Thanks for posting
  9. Tin Can
    Tin Can
    WOW, you are doing some awsome work on this car!
  10. Inland empire hot rods
    from so cal
  11. 1951Streamliner
    1951Streamliner
    from Reno, NV
    And it all started because of a busted differential :rolleyes:
    Fantastic work man, can wait to see more progress!!!!!
  12. the amount of cutting compound i use is nothing compared to how many of these suckers i munch through!
    pretty much finished the hinges tonight, i'm so stoked on how well they work because working out the geometry for them was a bit of a ball ache. i know that the heims aren't strictly traditional but you won't be able to see them when its finished and they are sooooo smooth! :)
    by the way nick, jamie says hello from guernsey! haha :)
  13. 30 Buford
    30 Buford
    Fine work , you are a crafty son of a gun . Nice ,Nice work and very time consuming . But it was well worth the extra effort . Thanks For Posting.
  14. jones
    jones
    from Dublin, Ca
    Gotta say that I've never seen hinges like that. Nice Job!
  15. mcknight05
    mcknight05
    from Ontario
    love the trunk hinges. the more holes the better. How many hours would you say?
  16. i wouldn't like to count the hours mcknight! they took as long as they took :)
    i've been beating myself up about what kind of steering to put in this car for months and months but i've finally let my brother bully me into probably the most involved, but i think coolest option. cowl steering.
    my good friend jamie (owner of a badass blown and chopped '34 coupe) sourced me a fully reconditioned steering box which was perfect for the job.
    i need to extend the shaft and make my own pitman arm so i chopped the big end off the stock pitman arm and plonked it in my little lathe and ended up with this splined bung-
    you can also see the steel tube that i'm using to extend it has been squared off and skimmed out on the lathe, then i ground a bevel to get good weld penetration. i also drilled some holes in the sides and loaded them up with weld for good measure. i put it back in the lathe to ensure everything was true before i tacked it.
    here it is after finish welding and turning smooth. turned out pretty good to say i've never made anything like this before!
    a 33mm socket was spun down on a bigger, more manly lathe than mine by a friend to slip inside the tube to crank the nut up.
    straight as a straight thing :)
    more tomorrow hopefully, i need to start planning a frame to mount the box to, i'm sure as shit not mounting it to the sheet metal like i've seen on some cars!
    catdad49 likes this.
  17. Gotzy
    Gotzy
    Once again Neil I'm enjoying you thought process, turning down the socket was a good answer to a need. What steering box did the Guernsey nut n bolt man get you?
  18. great to see, clever build with both form and function, all done with simple tools and a single shed.
    Quick question, how well does your seat fit now with those trunk hinges?
    Cheers,
    Drewfus
  19. you'll have to guess steve! its from a british commercial vehicle though, thats you're only clue.
    thanks drewfus, the seat fits just fine as i took that into consideration when making the hinges :) i'll be making a new bench seat anyway as it happens.
    got my mate eggy to put a 2'' wiggle in this seeing as i don't have a torch in my shed.
    mocked up with steering wheel i'll be using, anyone guess what it is?
    won't be needing this anymore-
  20. HotRodMicky
    HotRodMicky
  21. Your cowl steering set up is stout! Every thing about this build is first class.
  22. Very nicely done my man! First class work.
    Hack
  23. jamie34
    jamie34
    Went round to see Neil and to think I nearly threw that brand new Steering Box away and now look what Neil has done with it, great work Neil, you should put a picture up of what you looked like after 10 hours grinding and welding!
  24. langy
    langy
    Its all looking good Neil, look forward to seeing more.
  25. Great work for sure,love that theres no milling involved,just raw talent and time.
    Steering box looks alot like a landrover box but does'nt have the same 4 bolt plate at the base of it.
    Slitting disc's rule!
  26. [​IMG]
    :D
  27. Mart
    Mart
  28. TexasSpeed
    TexasSpeed
    from Texas
    Whoa. I look the same after a good day in the garage too.. :cool:
    I dig the level of fabrication in this build thread. You guys over the pond have some impressive skill!
  29. Noland
    Noland
    looking great, keep up the great work. thread is full of great ideas
