Technical Guide Coat
Discussion in 'The Hokey Ass Message Board' started by musew, Aug 1, 2017.
  1. musew
    musew
    Repainting my Morgan 4/4 (OK, no termite jokes) and have a question about guide coat.
    I understand the principle: block sand and the guide coat shows the low spots.
    My question is, does the guide coat stay on the car, or do you sand if off before applying filer and/or 2k primer.
    Seems to me that if you leave it on, you run the risk of a bad bond under the color coat.
    Its crumby single-part rattle-can paint after all.
    Sand if off and you've lost the visual id of where the low spot actually is.
    What am I missing here?
    Thanks in advance,
    Warren
  2. K13
    K13
    You sand it all off. You keep sanding until the the lows are gone (meet up with the highs). You may have to reapply filler and or primer to low areas to get to that stage but once you can sand everything without leaving any trace of the guide coat (no lows)you know your have it straight. Think of it like this, the guide coat shows you where you either have to take more product off (highs) or add more product (lows) the preference is obviously to take as much off as you can not to add more. There are actual guide coats available that are dry which will lessen the chance of "crumby paint" contaminating your work.
    48stude, Blue One and spurgeonforge like this.
  3. AngleDrive
    AngleDrive
    from Florida
  4. Paint_Rep
    Paint_Rep
    Rattle can paint is cheap, sandpaper-loading ****. Use a good aerosol powder based guide coat like SEM 38253 or Fibergl*** Evercoat 711. When you have straight/flat body work, the guide coat is gone after sanding. Any left and you have low spots...
    belair likes this.
  5. ronzmtrwrx
    ronzmtrwrx
  6. Bugguts
    Bugguts
    If I understand your question right. You are asking if you keep priming over the guide coating that is left in the low areas. Yes. I do prime over the guide coat that is left in lows. I've never had a problem yet. I use spray bombs and I have used the dry powdered stuff. Seems weird to leave it, but it's how it's done. I've been doing it for 34 years now.
    Sent from my SM-G900R4 using The H.A.M.B. mobile app
    Happydaze and JimSibley like this.
  7. I always thought you just fogged on a very light coat of a different colored primer. Either sand it off or cover with more high build if needed.
    afaulk likes this.
  8. musew
    musew
    Yea, that's what I was asking. Just seems strange to me to have guide coat layered-in under the surface once you're done. Maybe the fact that the guide coat is just misted-on, with plenty of surface left for filler or 2k to bond to, is what makes it work.
    Thanks to all who replied.
  9. willys36
    willys36
    It appears to be nothing more than lacquer primer. I always leave it and prime over it, no problems.
