Gun Blueing (or Gray)
Discussion in 'The Hokey Ass Message Board' started by Mike51Merc, Aug 24, 2011.
  1. Mike51Merc
    Mike51Merc
    Guys,
    I have some tools that have a gun blue or gray finish and it occurred to me that such a finish might be cool and effective on some car parts.
    Does anyone have sources and methods for doing this?
  2. I have Browned small parts but it is more durable than blueing.
  3. Ebbsspeed
    Ebbsspeed
    Do a search on "blueing steel" with Google or your favorite search engine, you'll get a few hits.
  4. Modern Blueing is done with an acid wash and is very delicate. Browning is more durable but if you want something that is actually going to wear oiling is your best bet. Not as shiney but done correctly on quality clean steel you can get the blue color.
  5. Unkl Ian
    Unkl Ian
    Did the suspension on a race car, with cold Blue, 25 years ago.
    Worked OK, but you had to worry about corrosion.
    Wouldn't try it on the street.
  6. All of my blackpowder stuff is browned and I have done steel bike parts. Takes beeswax and oil well for a very resistant coating.
  7. bgaro
    bgaro
    a fairly traditional way to finish a tattoo machine frame is to oil it. get it piping hot with a benzomatic and dip in (used) motor oil. i have tried some car parts with this method and have had good results. it gives u a darkened raw metal look
  8. CutawayAl
    CutawayAl
    from MI
    That is called "oil blackening". Old Rolls-Royce cars used the process on fasteners and ***orted small parts.
    Bluing isn't very rust resistant. If properly done, black oxide can look good, and it's cheap, but it also isn't very rust resistant. Phosphate coatings(zinc, iron, manganese) are more durable. Parkerizing is manganese phosphate.
  9. Mike51Merc
    Mike51Merc
    Thanks for the replies so far. I Googled a bit and found some good stuff including places to buy the stuff.
    I thought that some under-hood stuff like carb linkages may look cool and get some added rust protection.
  10. Zeke
    Zeke
    You have two options that you can use. Rust bluing which is old school and bluing salts. both are a pain in the ***. For small parts you'd be better off rust bluing, but it is time and labor intensive.
    Bluing with salts will lead to the **** getting everywhere and you boil the salts as part of a 3 tank process.
    Trent if they find out about browning someone is libel to do use it to patina a car.
  11. Its ok, there ain't a soul in the world with enough patience to properly brown and entire car!:D
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    still gotta oil it down every now and than ,, or it will corrode
  13. jfrolka
    jfrolka
    you can get patina kits... did the racecar frame in my avatar
  14. I browned a motor cycle seat once. :eek: I do have to say as a whole the job stunk but it was properly browned.
  15. theHIGHLANDER
    theHIGHLANDER
    From the FWIW dept, Packard V-12 instrument boards were silver oxide. I replicated the look by getting them silver plated (not as pricey as it sounds) then masking the non-oxide areas off. I would apply gun blueing solution to the oxide surface and rinse it immediately. it gives a lovely satin gray background next to the gauges. To reduce maintainence I would spray a very thin coat of clear urethane over it after a thorough soap n water bath followed up by an alcohol wipe down. I'd reduce the clear like 200%. The last one I looked at from my past was 18yrs old and had one 1/4 by1/4 spot of tarnish in a corner. Just an idea...
  16. greg32
    greg32
    from Indiana
    While looking at Miller race cars at Milwaukee a couple of years ago, noticed the quarter eliptic springs were blued. Neat look. The owner said he first metal polished leaves, then blued them.
  17. Kevin Lee
    Kevin Lee
    Super Moderator
    haha.
  18. Dirk35
    Dirk35
    Bluing isn't very rust resistant, even the stuff our rifles and machine guns are finished with. We have a whole arms room full of weapons with a dehumidifier running 24-7 and still get little rust spots. We make the Soldiers clean them well, but could do a better job at not turning them in dry so they will p*** the armorer's inspection.
  19. 28dreyer
    28dreyer
    from Minnesota
    I did the polish then painted the tops and bottoms of the leaves that were not visible from the top and spread heavy marine grease interleaf. Tried clear coat on the exposed shiny portions but after a season of vintage dirt racing the exposed clear coated areas have yellowed/browned with some corrosion.
    Plan on taking them all apart this winter to see what the interleaf areas look like.
    Would consider blueing the exposed visible areas if the interleaf treatment has held up.
  20. hotrod40coupe
    hotrod40coupe
    If you want that look without the corrosion problem, try Black Chrome.
  21. yellow dog
    yellow dog
    from san diego
    No match for black chrome, however I use for re-blueing fasteners after I've cut. Its okay as long as it never sees moisture. I suppose its available everywhere, but my kit says "Precision Brand" and w/ the cleaner works better than my 1st attempts w/ a bottle from Walmart gun dept. Selinium component always a negative....use gloves
  22. 57JoeFoMoPar
    57JoeFoMoPar
    As mentioned, bluing isn't very rust resistant at all. I have a blued revolver that I keep inside and in it's case, but it still needs to be oiled to prevent small rust spots. Looks great, but a pain in the ***
  23. greg32
    greg32
    from Indiana
    Well, I have quite a few handguns from the late 60s, S&W and Colts that look brand new. Always keep a light coat of gun oil on them, and wrapped in a clean white tee shirt rag.Even in the midwest they stay nice if you keep finger prints off them. On a car part exposed to the elements, I can see a durability problem. Someone said parkerizing, I have a WWII .30 carbine that still looks nice. I like that finish a lot.
  24. CutawayAl
    CutawayAl
    from MI
    Parkerizing is more rust resistant than bluing, but neither are very good for typical automotive exposure.
  25. Larry W
    Larry W
    from kansas
    Just like a good looking women,it is very high maintenance. Blueing looks good, but take care of it,it will rust.
  26. Mike51Merc
    Mike51Merc
    I started this thread because I have some old precision hand tools that are blued (or greyed). In the places that the finish is worn and missing they have surface rusted. Obviously the coatings have provided some corrosion resistance, not to mention that they suffer from the typical moisture from manual handling.
    I thought that bluing would be cool on some carburetor components (rods and linkages) for a different look and some corrosion protection as well.
