Hot Rods guys running t bucket sbc 671
Discussion in 'The Hokey Ass Message Board' started by c/h, Oct 16, 2023.
  1. c/h
    c/h
    from iowa
    im having a time getting a alternator installed in my T with sbc and a 671 running into Clerance issue.
    have the mounting kit from speedway for lower on drivers' side but having interference with frame and alternator.
    hoping someone had the issue and figured it .
    thank you
  2. silent rick
    silent rick
  3. Lloyd's paint & glass
    I ran that bracket in my last 29, the frame was 2X3, I had to cut a piece out for alternator clearance, flipped it over, and welded it back in.
  4. flatheadgary
    flatheadgary
    from boron,ca
    if the frame is 26" on the inside there is no problem. i know this is not very helpful just info.
  5. Mr48chev
    Small body alternator?
  6. 19Eddy30
    19Eddy30
    from VA
    More likely your will have to fabricate,
    Mount the Alternator on driver or p***ager side between blower & valve cover ( big GM ), I made my own to mount low & under ( mini ) IMG_0965.png IMG_0964.png
  7. DDDenny
  8. c/h
    c/h
    from iowa
    yes im at 22 inches.
    heck of a job notching the frame.
  9. Phil P
    Phil P
    I put in one of those Denso Hot Rod mini alternators and modified the speedway bracket. IMG_1673.jpg
    Phil
    Toms Dogs, mad mikey and Just Gary like this.
  10. c/h
    c/h
    from iowa
    would that be denso tds 721? parts number
  11. c/h
    c/h
    from iowa
  12. Phil P
    Phil P
    Budget36 likes this.
  13. Lloyd's paint & glass
  14. c/h
    c/h
    from iowa
    thats a better deal quite a cost savings
    this site sure is helpful
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    The frame rails @ the front of the engine on my T are a touch over 20" apart . I made a low mount alternator bracket for the p***enger side that has worked fine for 22 years & 50k miles. I'll see if I can remember to get pics tomorrow
  16. swade41
    swade41
    from Buffalo,NY
    I made my own out of various factory parts that I modified, I wanted the low mount but my steering box is in the way.
    Desoto291Hemi likes this.
  17. c/h
    c/h
    from iowa
    this mini bracket and alternator work out well. had to modify the bracket but took few minutes to do.
    top bolt fit but bottom short so cut the bracket not all the way but enough to line up bottom bolt ran it thru and welded up the difference few minutes work.
    thanks for all the help and input.
    swade41 and 2OLD2FAST like this.
