H.A.M.B.Drags Drama
Discussion in 'The Hokey Ass Message Board' started by Yo Baby, Aug 20, 2007.
  1. Yo Baby
    Yo Baby
    It's Mon.10:27 P.M........Do you know where your Hot Rod engine is? ;)
    Here is part of mine,the crank and 1 head are at the machine shop,ready to be gathered up in the morning.
    Still have a pin hole in a water jacket that at the present time looks to be relatively irrepairable.:( (I'll think of something)LOL
    To make matters worse,it's self inflicted.:eek:
    However I still intend to be there with bells on.:D
    Anyone else working through a little 13th hour drama?
  2. Don Moyer
    Don Moyer
    Hahah, my buddy Eric, (lurker) just picked up a core th400 tonight at 11:15 to replace his broken case on his Gene Swartz clone g***er....So he has to rebuild it and put it in before we hit the road on Wed....So your not alone, and you can get it done. Don
  3. Rusty
    Rusty
    What is that? no Coupe this year?
  4. Yo Baby
    Yo Baby
    Ha Ha,I'd rather be doin' the trans for sure..
    Hey Dirty,that's correct,no coupe this year,just that ugly little white car.LOL
    See ya there.
  5. AHotRod
    AHotRod
    Best of Luck to you, I hope to see you there!
  6. Thirdyfivepickup
    Thirdyfivepickup
    looks heavy duty, good luck!
  7. Roothawg
    Roothawg
    I figure if anyone can scrounge up the stuff to get her going Yo Baby can.
  8. ratso575
    ratso575
    sounds like some of those last min. gremlins are cruisin your garages ....... too !
    I took the 37` out sunday to a car show in salida co. , as I pulled up to register , the frickin clutch peddal went to the floor ....
    I got out and saw a small trail of brake fluid behind me , looking under the truck I saw fluid running out of the bellhousing :mad:
    I got lined up and parked my truck , with some pushing help from some fellow car show folks ... the show was awesome , met alot of new people and had alot of fun b.s.ing ........
    my freind animal showed up , drove his 56` plymouth from hooper co. ....... after the show he ran me over to where I had my truck and trailor parked , got the 37` loaded and headed home , ran into a rain storm , had a blowout on the trailor , thats about all that happened :rolleyes:
    pulled the trans that nite , found that the bleed hose for the hyd. throwout brg had a hole in it from the pressure plate ....... had a new hose in and up and running by 9:00
    thanks to animal for your help , nice to have freinds , that are true freinds !!!!
    see you all at mokan !
    ratso
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    If it wasnt for 13th hours emergencies I'd never get anything done!
  10. Kerry
    Kerry
    Pinhole in the water jacket? My hemi block has several impressive cracks on the right side. The machinest I had used didn't notice the cracks till he was done. :-/ They looked like they had been silver soldered and he said they wouldn't leak but he was wrong. I did some welding on them so they don't open up and then a healthy layer of JB weld. After a couple of years is twa weaping some so a couple of nights ago I cleaned off the loose JB and put some more on. Jury rigged... yes but it's held so far.
  11. SpeedRacer2002
    SpeedRacer2002
    hell im way behind... got my car bagged and 4 linked but now i have to step notch the rear because it sits like a 70s chevelle still... get exhaust on and get gl*** cut and installed and put in my gas tank and hope to hell the brakes still work... oh and wire headlights and tail lights... and time permits ill put in a radio too....
  12. Yo Baby
    Yo Baby
    I'll be sure to have lots of beer and a swig or 2 for you 13th hour guys.LOL
    At the present time I'm takin' a break to feed the family but have the head and the crank back and the block is cleaned up and the new cam bearings installed and the cam and is ready for main bearings and the crank.
    Come on with your bad selves and lets have some fun this weekend.
    I'm lookin' forward to dueling with Daves Deuce and Becks Coupe and metting the Speed Racer 2002.
    More updates later.
    T.OUT
  13. Boynamedsue
    Boynamedsue
    try block cementing the pinhole it should work for a little while, that or weld it up.
  14. zman
    zman
    from Garner, NC
    I'm feeling like I may have to show up in the late model, to many small things left to do on my '57 for the 1,100 mile trip (each way). I was going to have tomorrow off to work on it, but **** happens. Oh well, I can carry more beer this way.
